Ground Clearance on a Stock KJ - JeepForum.com
post #1 of 12 Old 11-13-2013, 03:45 PM Thread Starter
Thelt
2005 KJ Liberty
How much ground clearance do you think the average stock KJ has. Mine is a 2005 so I figure the springs have sagged some so it has less than it did when new.
2005 KJ Sport 4x4
1998 ZJ with inline 6
I hate environmentalists, they keep me from enjoying the environment.
Thelt is offline
post #2 of 12 Old 11-13-2013, 07:25 PM
tommudd
2004 KJ Liberty
Depends on how much yours has sagged
if you have skid plates and what brand they are
what size tires you have on
etc
all of the above makes a difference, best bet is to take a tape measure and crawl under yours
04 KJ WITH JBA 4 INCH COILOVER LIFT
03 KJ WITH JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #3 of 12 Old 11-14-2013, 11:29 AM
tjkj2002
2002 KJ Liberty
If your running stock sized tires it's the same from '02-'13(KJ and KK) since the lowest point is the center of the rear diff.Only tire size effects that measurement.No amount of sagging will effect ground clearance when your lowest point is the solid diff.
tjkj2002 is offline
post #4 of 12 Old 11-14-2013, 12:47 PM Thread Starter
Thelt
2005 KJ Liberty
OK, I did not realize the rear diff was the low point.
2005 KJ Sport 4x4
Thelt is offline
post #5 of 12 Old 11-14-2013, 05:43 PM
Luke09
2005 KJ Liberty
... and the only way you'll ever change it is with bigger tires .. even then, unless your Troy , it's negligible.
2005 Liberty Renegade - Dark Khaki
Frankenlift IIP, Mobil1 Synth.& Filter, PIAA Extreme White, Amsoil EA Filter, Spidertrax 1.25, 245/75/16 Duratracs
Luke09 is offline
post #6 of 12 Old 11-15-2013, 01:11 PM Thread Starter
Thelt
2005 KJ Liberty
A Subaru Forester has 8.7 inches of ground clearance. I am thinking that is more than my KJ has so it should be able to handle the beach as well as my KJ.
2005 KJ Sport 4x4
Thelt is offline
post #7 of 12 Old 11-15-2013, 03:34 PM
2007LIB
2007 KJ Liberty
That all depends on how stuck you want to get.
If it ain't broke don't fix it.....Enjoy it.
2007LIB is offline
post #8 of 12 Old 11-15-2013, 03:50 PM Thread Starter
Thelt
2005 KJ Liberty
I do not want to get stuck that is why I am trying to figure out if a forester has enough clearance. 8.7 inches is pretty good for a stock vehicle, more I suspect than my KJ has.
2005 KJ Sport 4x4
Thelt is offline
post #9 of 12 Old 11-15-2013, 04:16 PM
2007LIB
2007 KJ Liberty
I suspect that 8.7" clearance is is for the complete body not just for a few points on the structure and that would mean there is going to be a lot more drag on the vehicle if you do get to the clearance limit.
The low points on the jeep are on certain spots and would give you a lot less drag at the limit.....Better mileage vs better towing..... Choices, choices.....
2007LIB is offline
post #10 of 12 Old 11-15-2013, 09:39 PM
Luke09
2005 KJ Liberty
I measured mine tonight ... the very bottom of the rear diff is just shy of 9"
but everything else is waaay higher than that
Luke09 is offline
post #11 of 12 Old 11-15-2013, 09:43 PM
Ralphrlong
As I am sure has been discussed many times on this forum, even a stock XJ can do amazing things with skillful driving and a spotter.
Don't let being stock keep you from having fun on the trails!
My jeep is pretty stock and I have done some pretty technical four wheeling. Just gotta go slow and have as spotter. And be willing to move some rocks.
Ralphrlong is offline
post #12 of 12 Old 11-15-2013, 09:45 PM
tjkj2002
2002 KJ Liberty
Yep mine is 11.5" at the rear diff(HP60),12.5" at the front diff(HP44) and 23.5" at the center belly pan.
tjkj2002 is offline
