Got stuck in mud real bad - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Got stuck in mud real bad
ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO TeraFlex JK 2/4 Door 2.5" Lift Kit!! DEALS AT ROCKRIDFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 04-29-2012, 11:04 PM   #1
05MuddyMUT
What damage should I look for because I decided to go off roading today and went through mud with alot of rocks in it what damage should I look for
05MuddyMUT is offline   Reply With Quote Quick reply to this message
Unread 04-29-2012, 11:07 PM   #2
justanotherjpr
Something broken or sounds bad? If there was lots of water you will need to check diffs, t case and transmission for water.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline   Reply With Quote Quick reply to this message
Unread 04-29-2012, 11:14 PM   #3
piraterig
wash it, damage is its muddy most likely. then if something makes a sound or acts odd start there. if it was water check fluids. or if you was reverse to drive bombing the tranny you may get some issues. had to say when all you gave us was, it got stuck bad.
04 WJ stock, saving funds for mods
95 ZJ 30x9.50s kumho at
96 XJ sport with stuff, sold
piraterig is offline   Reply With Quote Quick reply to this message
Unread 04-29-2012, 11:15 PM   #4
05MuddyMUT
I don't think anything broke or sounds bad but the brakes don't feel right and thanks I'll check the trans and the diff
Unread 04-29-2012, 11:18 PM   #5
05MuddyMUT
The mud was mostly water up to the bottom of my door sill and the end of the exhaust was in the water but wasn't forced into the pipe
Unread 04-30-2012, 12:41 AM   #6
justanotherjpr
Clean off all the mud check the vitals for water and then see if everything works/ sounds ok
Unread 04-30-2012, 01:54 AM   #7
01CHEEKEE
2004 KJ Liberty
The brakes not feeling right is most likely due to mud caked on wheels causing them to be off balance...clean all mud off, I suggest taking to a car wash so it's not your prob afterwards, then most suggest to change your front n rear diff fluids...then check for damage, but unless you heard something crack or rock teh jeep hard you're prob fine
01CHEEKEE is offline   Reply With Quote Quick reply to this message
Unread 05-02-2012, 07:20 PM   #8
DaveJKJ
2005 KJ Liberty
Been there and done that more than once.
First power wash the outside and get the wheel wells real good until the mud and debris stops dripping onto the tires and wheels. Then lift the hood and spray all the mud that was dripping off the inside of the hood and then the entire engine bay. Underneith, power spray everywhere, especially the brakes and nooks and crannies everywhere. Rip out the mud and grass and sticks and stones that are dripping and drooling everywhere underneith. Get a garden trowl and scoop the mud and debris out of the skids. Keep scooping using your trowl, hands, and a big ugly screwdriver if necessary. Spray it all again. Spray it all again. Maybe a third spray if necessary. make sure you get it all out of the inside of the wheels so you don't get death wobble from unbalanced wheels. Double check breather lines for diff's, tranny etc to make sure they are still attached etc, wireing etc. Check fluids. Check everything underneith again. Take a shower. Drink a six-pak and relax.
Two weeks later you will still have dried mud caked and baked on under the jeep in places. As time passes it will dry and fall out all over the road every time you hit a bump. No one will tail-gate you.
Don't do that again......unless you are stupid like me......haha
War Veterans Jeep Group #31
Black Jeep Society #217
DaveJKJ is offline   Reply With Quote Quick reply to this message
