Going into 4 wheel drive - JeepForum.com
post #1 of 7 Old 11-15-2010, 06:22 PM Thread Starter
meggie80
2006 KJ Liberty
I am hoping someone can help with this. I have a 2006 jeep liberty 6C 3.7L
4x4 and might have to use the 4 wheel drive this coming winter. (I live in Seattle so we don't get to use the 4x4 in the snow often) I remember when I bought the car that the dealer said the switch to 4low or 4h that i could just pull off the road but I don't remember if i need to put it in neutral or just step on the brake and switch. I tried looking for my owners manual but can't locate it. This is my first car and first time with 4 wheel drive so any and all information someone can give me would be great. Thanks!
meggie80 is offline
post #2 of 7 Old 11-15-2010, 08:27 PM
Nick_Knipp
1986 MJ Comanche
(sighs) trying to remember the liberties selections, on the 4x4 shifter next to the transmission shifter. does it go as following
2H
4H
N
4L
if not please tell me the lettering
"Don't curse in your profile"
-The Moderators
'86 MJ XLS 4x4 2.8L 3spd longbed buckets
'12 MK Sport 2.4L AT rescue green
Nick_Knipp is offline
post #3 of 7 Old 11-15-2010, 08:28 PM
LibertyTC
2004 KJ Liberty
I always switch into Neutral then into 4 WD modes then back into Drive with 2004 command Trac.
The owners manual can be downloaded in pdf here:
Chrysler Canada Inc. - Chrysler Jeep Dodge Owners - Owner/Service Manuals
LibertyTC is offline
post #4 of 7 Old 11-16-2010, 07:37 AM
WXman
First of all, NEVER use 4-Low on the highway. You will toast your drivetrain.
Now that we have that established... You can use 4-Part Time in the snow by simply pulling the lever into that position any time. Stopped, moving, it doesn't matter. Even up to 55 MPH you can shift into 4-Part Time.
Keep in mind that doing this locks the front and rear driveshafts together, so ONLY use this on slippery roadways.
IF you have 4-Full Time.... you can shift into that mode and leave it there all Winter long if you choose.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #5 of 7 Old 11-16-2010, 08:50 AM
Nick_Knipp
1986 MJ Comanche
Here are the suggested uses for the following settings
2HI - normal driving conditions
4HI(full time) - slippery surfaces (rain, snow, dirt, gravel, sand, clay, mud, ice, etc)
4HI(part time)- moderate to severe uses (mud, snow, ice, etc)
N- when towing the vehicle put into neutral
4LO- severe traction control, DO NOT use on dry surfaces or speeds over 10mph. Mainly for getting out/thru difficult slippery terrrain
2LO- for rock crawling, rarely used
-The Moderators
post #6 of 7 Old 11-16-2010, 09:06 AM
tjkj2002
2002 KJ Liberty
4HI(full time) - slippery surfaces (rain, snow, dirt, gravel, sand, clay, mud, ice, etc)If you have the 242 t-case only
4HI(part time)- moderate to severe uses (mud, snow, ice, etc) Do NOt Use On Wet Roads
4LO- severe traction control, DO NOT use on dry surfaces or speeds over 25 mph. Mainly for getting out/thru difficult slippery terrrain
2LO- for rock crawling, rarely used Not a OE option,must spend $1000+ to have this option
Fixed if for you.................
You must put the trans in "N" while coasting at about 2-3mph to shift into 4low.
tjkj2002 is offline
post #7 of 7 Old 11-16-2010, 09:58 AM
Nick_Knipp
1986 MJ Comanche
Thanks, I only put in the symbols we would normally see in the vehicles. Was just being general. Also before switching options, slow the vehicle to a 'stop', then shift to neutral, and switch.
-The Moderators
KJ - 2 Wheel Drive, 2.4L, Manual casadelrob KJ Liberty Forum 3 08-24-2010 07:25 PM
Help using 4 wheel drive. winter1 KJ Liberty Forum 11 12-10-2009 05:32 PM
4 wheel drive? Ernee KJ Liberty Forum 9 06-07-2008 10:07 PM
How do I get out of 4 wheel drive? Morgansmorgue KJ Liberty Forum 7 08-19-2006 09:21 PM
ABS in Four Wheel Drive schlundg KJ Liberty Forum 7 12-10-2005 08:34 AM
