Gauge cluster light types? - JeepForum.com
post #1 of 15 Old 03-23-2010, 09:46 AM Thread Starter
Lace
I just finished a LED conversion with my TJ and the fiancee loves it and wants her KJ (2006 limited) to be fitted with LEDs.
I found the manual online but it's telling me:
Interior Lights Bulb Type
A/C Heater . . . . . . . . . . . . . . . . . . . . Not Serviceable
Ashtray Receiver Light . . . . . . . . . . . . . . . . . . . . 161
Climate Control (Manual A/C). . . . . . . . . . . . . . . . 74
Front Reading . . . . . . . . . . . . . . . . . . . . . . . . . . . 192
Rear Cargo Light . . . . . . . . . . . . . . . . . . . . . . . 2142
Lighted Vanity Mirror *. . . . . . . . . . . . . . P/N 6501966
Underpanel Courtesy Lights. . . . . . . . . . . . . . . . . 906
Instrument Cluster (General Illumination) . . . . . . . 103
Telltale/Hazard Light . . . . . . . . . . . . . . . . . . . . . . 74
I cant find any 103's for the life of me.
Do any of you happen to know which size bulbs the instrument panel uses?
- Local jeep forum!
2003 Wrangler X 4.0L | 2006 Liberty Limited
2006 Grand Cherokee Limited 4.7L - Traded |2005 Liberty Limited - RIP
Lace is offline
post #2 of 15 Old 03-26-2010, 08:02 AM
Billwill
2002 KJ Liberty
The panel has 9..I think...small bulb assemblies plugged in at the rear of the cluster. I think they are specific Jeep only bulbs. The Sticky above, "Liberty Service Manual", has section 8, wiring diagrams (about 42MB). This gives you the circuit diagrams and also describes how to take the panel apart and remove the bulbs...this download is for 2002 models, gas or diesel, LHD RHD etc. but should be valid for later year models.
How are you going to dim the panel lights if you use LEDs? Fit a complete seperate circuit?
Billwill is offline
post #3 of 15 Old 10-14-2014, 03:04 PM
x556
Any luck on finding those 103's? Mine has the temperature side of the cluster blown and it's driving me nuts! I have a 2006 Jeep Liberty Limited
x556 is offline
post #4 of 15 Old 10-15-2014, 08:36 AM
brendanc
2002 KJ Liberty
PC74 may work for you.
What I did, so that I didn't have to go back in there again, was buy 9 "PC74" led bulbs. Their sockets were not compatible, so I pulled the led housing out of each of the bulbs (you will know what I mean if you go this route) and also carefully pulled out the bulbs from the OEM bulb sockets. Then I put the led bulbs into the OEM bulb sockets and soldered them to the contacts. Took some trial and error due to their polarity (you can turn the bulb 180deg in the socket, so no need to worry about soldering them wrong) but ended up fixing them permanently.
You will need a needle point soldering iron (not one of those big Weller guns unless you have a special tip) and some patience if you are to do this. I would recommend, if you can, getting a soldering station with a variable temperature adjuster and setting it to around 800F. That way the work can heat up quickly so you can solder, and it will be quick enough that you wont melt the plastic socket.
Good luck!
Edit: Pictures!
02 Liberty, 4" JBA Gold Lift
brendanc is offline
post #5 of 15 Old 10-15-2014, 04:57 PM
95BadBoy
As they say, pictures are worth a thousand words. Nice
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #6 of 15 Old 10-19-2014, 09:46 AM
x556
Amazing! Thanks a lot bro, I'll let you know when I'm done with these thingies!
x556 is offline
post #7 of 15 Old 10-19-2014, 05:32 PM
x556
Ok so my patience ain't good as yours and I ended up shorting the cluster. I couldn't manage to get the pins to solder to the exposed metals on the twist connectors. So I ordered these http://pages.ebay.com/link/?nav=item...d=111462217772
I think they will easier to handle. Will keep you on the know how well these worked for me.
x556 is offline
post #8 of 15 Old 10-21-2014, 01:04 PM
brendanc
2002 KJ Liberty
Interested to know how that works out. I agree, it took me several tries on a few of the connectors. I had to tin a few of them to get the solder to stick. Also, I used very thin gauge solder. If I could have found the same gauge in lead solder I would have used that, as lead-based solder tends to mate two surfaces together better than the stuff without it.
Patience definitely helps. Having one of these helps too (RadioShack Digital Soldering Station):
Got it on sale a year or so ago for $79
brendanc is offline
post #9 of 15 Old 10-22-2014, 09:13 AM
x556
Originally Posted by brendanc
Interested to know how that works out. I agree, it took me several tries on a few of the connectors. I had to tin a few of them to get the solder to stick. Also, I used very thin gauge solder. If I could have found the same gauge in lead solder I would have used that, as lead-based solder tends to mate two surfaces together better than the stuff without it. Patience definitely helps. Having one of these helps too (RadioShack Digital Soldering Station): Got it on sale a year or so ago for $79
Will do buddy. I had issues with the sizes of LEDs I bought as well. I think I made a mistake in the size when ordering, hopefully the others will do the trick. Can't wait for them to arrive!
x556 is offline
post #10 of 15 Old 10-22-2014, 11:07 AM
remmons
My knowledge of LED's is somewhat limited. On the dash applications, are they dimmable? If not, is there another component that is required to be added in for the purpose of dimming the LED's?
Robert.
remmons is offline
post #11 of 15 Old 10-22-2014, 12:03 PM
brendanc
2002 KJ Liberty
They dim just fine for me, but under a hunch I got the "regular" LEDS (superbrightleds.com) and not the "high power" ones, and while they're brighter at the lowest setting compared to their incandescent cousins, they have a pretty decent range of dimming.
The white LEDs did wash out the "green" of the instrument panel, though. It looks more like light blue now.
brendanc is offline
post #12 of 15 Old 10-23-2014, 08:35 AM
x556
They dim just fine for me, but under a hunch I got the "regular" LEDS (superbrightleds.com) and not the "high power" ones, and while they're brighter at the lowest setting compared to their incandescent cousins, they have a pretty decent range of dimming. The white LEDs did wash out the "green" of the instrument panel, though. It looks more like light blue now.
I wonder how blue is gonna turn out in mine...
x556 is offline
post #13 of 15 Old 10-23-2014, 04:42 PM
remmons
I might have to give these a try, but maybe at a future time.
Robert.
remmons is offline
post #14 of 15 Old 10-23-2014, 09:13 PM
brendanc
2002 KJ Liberty
If anyone is looking for the LEDs I have used in the picture, it's these:
https://www.superbrightleds.com/more...panel-led/709/
The bulb itself seems to be a generic (for SBL, at least) one that plugs into several different sockets. You just carefully bend out the leads and cut the bit they were wrapped around about half way (as seen in the picture above). Hot glue into the socket and then worry about soldering. I wish I had taken more pictures, but it should be relatively easy to figure out.
brendanc is offline
post #15 of 15 Old 07-16-2015, 09:49 PM
LunchboxSenior
2002 KJ Liberty
I ran in to the same problem as brendanc, and was inspired by his solution. However, I was too lazy to solder or hot glue and just wrapped the LED leads around the socket contacts. Worked like a charm!
LunchboxSenior is offline
bulb , gauge cluster , led , limited , size
Lightbar light on instrument cluster spoon KJ Liberty Forum 4 12-26-2009 01:51 AM
Instrument cluster wbrewski KJ Liberty Forum 0 12-01-2007 03:11 AM
Any interest in a 3-pod pillar gauge cluster for the Liberty Tom_with_a_Drea KJ Liberty Forum 0 06-29-2006 08:51 AM
Cluster/Gauges dropping out? thepowertowin KJ Liberty Forum 2 05-06-2006 09:59 AM
Instrument Cluster jesserb306 KJ Liberty Forum 2 01-25-2006 11:02 AM
