Gasket Problem? - JeepForum.com
post #1 of 3 Old 11-23-2009, 07:35 AM Thread Starter
jbaglien
2003 KJ Liberty
Gasket Problem?
I have a 2003 Jeep Liberty Sport with 130000 miles on it. The check engine light is not on, it does not appear to be burning oil, runs great and the problem does not happen all the time (it is happening more frequently now). It happens only on short trips from the store, 5-15 miles of driving. If I'm coming to a down hill/slope stop and turning right, the engine or under the hood with let out a poof (I don't hear it or see it) just smell it. When I look under the hood, there appears to be a build up of dirty oil below the area where I would add oil and on two hoses in front of the area when oil is added. I have tried using an oil additive, oil for high millage cars that state they help leaks, but that did not help. Any suggestions - I'm unemployed and would like to try to fix it my self it at all possible. Thanks
jbaglien is offline
post #2 of 3 Old 11-23-2009, 09:23 AM
valvestem
valvestem's Avatar
Have you ever changed out the PCV valve?
valvestem is offline
post #3 of 3 Old 11-23-2009, 11:20 AM
LibertyTC
2004 KJ Liberty
The gunk build up below the cap can be cleaned with var sol .
Good idea to replace the pcv valve on the side of the oil filler tube.
Which oil additive did you use? When was the last time the spark plugs were changed? I replace my plugs every 25K miles.
I also would make sure that inside the air filter box is totally spotlessly clean, and if the air filter is dirty get a new one.
Next is on to cleaning the throttle body intake. Use carb cleaner spray and get any dirt /carbon built up inside the throttle body, out of there, using the spray and a lint free shop towel. The throttle body swing plate should be clean too.
After it is clean I also use a fine oil applied to the horizontal swing plate round bar, where it mounts on the throttle body. I also clean the outer edges of the swing door/plate on the out side edges, and then apply fine oil, on those out side edges as well, to ensure a smooth movement of the throttle plate door.
Has this engine ever had a professional oil flush? In your motor have you been using conventional motor oil or synthetic oils?
Getting the motor inside clean is also important. I always change my filter when oil change is done. Never just dump the oil with out a new filter.
If you have been running conventional oils, change it to synthetics as it will help to clean the motor better than the cheaper conventional oils and lubricate stem seals better as well.
I am not sure where you leak is coming from, possibly you could get a photo and PM me so I could look at it better.
LibertyTC is offline
Leaking antifreeze from gasket head liberty2003 KJ Liberty Forum 7 10-19-2009 06:35 PM
Lubelocker gasket dcxman KJ Liberty Forum 4 02-24-2009 09:28 PM
does rear diff need gasket to change oil? SpaComponents KJ Liberty Forum 8 05-01-2007 11:24 AM
Overheating - blown head gasket Dirtnapper KJ Liberty Forum 9 08-13-2006 07:44 PM
RB1 GPS problem LIYANG KJ Liberty Forum 2 08-19-2005 11:01 AM
