Fuel tank filler problem - JeepForum.com
post #1 of 4 Old 07-10-2013, 10:27 AM Thread Starter
Komodo
2005 Jeep liberty limited
Automatic
Gas engine
V6, 3.7 L
Purchased in Canada
70.000 miles
I got an OBD2 trouble code P0456 (EVAP, very small leak) and P0457 (fuel cap loose/off).
I tried to change the fuel cap and the problem came back, so I took it to the dealer and he said the next step is to change the gas fuel tank filler neck hose. He said he tested it with smoke but wont tell me were the leak is, just the hose needs to be replaced, $615.00.
Is there some kind of sealer I can use instead of replacing the whole unit and if not, can I do the job myself in a home garage. Im not an auto mechanic, but I am handy with tools.
Komodo is offline
post #2 of 4 Old 07-11-2013, 10:47 AM
tjkj2002
2002 KJ Liberty
If you do need that filler hose you must drop the gas tank to do so and those hoses are special hoses and pricey.Just check out pricing of larger diameter fuel hose and you will see it's not cheap.
tjkj2002 is offline
post #3 of 4 Old 07-11-2013, 03:46 PM
95BadBoy
One of the GM dealers in my neck of the woods does charge a cool 1 K to replace a fuel pump on a late model pickup, they left the tank in the frame. I watched as they lifted the bed off, then replace the pump - and drop the box back on. Just how they do it I guess.
I do not have any real comparison for the KJ's though.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #4 of 4 Old 07-11-2013, 03:58 PM
tjkj2002
2002 KJ Liberty
Yeah you can get away with pulling the box on a pickup,not always pratical though as it does take 4 poeple to remove and install it.You can't do the same on a KJ.
You also gotta think a high quality fuel pump will run you $500-$700 alone and generally most vehicles with in-tank pumps call for between 2-4 hours to remove/install the gas tank.A few,very few actually, you can change the pump without dropping the gas tank like the xterra which has a in-cab access panel(bolted on).
tjkj2002 is offline
