Quantcast fuel filter change - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > fuel filter change
Old 10-09-2006, 11:02 AM   #1
dcxman
2006 KJ Liberty
fuel filter change
Okay, who has changed the fuel filter. Does it take a crow bar, or just a
big hammer?
dcxman is offline   Reply With Quote
Old 10-09-2006, 11:21 AM   #2
rob92xj
1992 XJ Cherokee
Should need just a few wrenches, don't for get to prime the fuel system after replacing the filter and DO NOT pre fill the filter install it empty, pump the primer about 10x and try to start it if it does not start in ten seconds, pump the primer another 10x. Cranking the engine over 10 seconds willl damage the CP3 high pressure pump, it's a good pump just not tolerent of no fuel volume due to the very close tolerences in it.
rob92xj is offline   Reply With Quote
Old 10-09-2006, 02:33 PM   #3
Maximum Carnage
2002 KJ Liberty
I haven't looked for the fuel filter yet. But where is is located?
Maximum Carnage is offline   Reply With Quote
Old 10-10-2006, 05:49 AM   #4
rob92xj
1992 XJ Cherokee
The CRD fuel filter is next to the brake booster. Gas KJ it's in the tank.
Old 10-10-2006, 06:49 AM   #5
m90daytona
so if its in the tank how do you change it? pull the sending unit?
m90daytona is offline   Reply With Quote
Old 10-10-2006, 08:21 AM   #6
dcxman
2006 KJ Liberty
Is it necessary to loosen the relief valve to pump air out of the cannister? I believe that is what I did when I drained the filter once checking for water.
Old 10-10-2006, 11:51 AM   #7
rob92xj
1992 XJ Cherokee
The bleeder valve next to the filter is for draining the water out of the water seperator, lossen the bleeder then open the drain valve.
Have the bleeder closed when you are priming the fuel system with the hand pump mounted to the filter housing.
Old 10-10-2006, 12:18 PM   #8
dcxman
2006 KJ Liberty
Thanks Rob,
One more question.. Does the cannister screw on?How does it work?
Also, today changing diff oil in the 96 Ram. Just using OEM rated non-syn oil.
What do you use in yours?
Old 10-11-2006, 10:03 AM   #9
m90daytona
off topic, can you change the fuel filter in the 3.7 liberty if its in the tank?
Old 10-11-2006, 11:26 AM   #10
Steven73
changing the fuel filter
I was told by the Jeep dealer that it's a lifetime filter, and that it doesn't have to be replaced until the time comes to also change the injector pump. They said that today's gasolines are refined well enough so that changing filters every 6,000 miles isn't necessary. At least that's what they said. I use a bottle of STP fuel injector cleaner in my gas tank every 3000 just to make sure everythings kosher.
Steven73 is offline   Reply With Quote
Old 10-11-2006, 11:43 AM   #11
rob92xj
1992 XJ Cherokee
The gassers fuel filter should be changed every 100,000 miles but nobody does replace it. It is mounted on the bottom of the fuel pump module.
DCXman I used 75W140 in my 00 Rams front and rear diffs and my 03 Ram uses 75W90 syn in the front and 75W140 in the rear, anything with a tow package or used to tow anything should have 75W140 in the rear.
Old 10-11-2006, 11:53 PM   #12
lucas/liberty
gassers have two fuel filter, 1 is in tank, 2 is right next to it, access from inside the cab/trunk per chilton book manual...
...you dont stop playing just because you get old, you get old because you stop playing...
...If a man speaks in the woods where there is no woman to hear him, is he still wrong?
Wife=2002 jeep liberty sports traded it in for an RX330 lexus
===2007 nissan Xterra X
lucas/liberty is offline   Reply With Quote
Old 10-12-2006, 07:20 AM   #13
BVCRD
The one on the fuel pump is likely the most frequently changed. Unfortunately, the one in the tank is probably the most needed to be changed (if ever) because it is the first line of defense.
2006 Jeep Liberty Sport CRD
BVCRD is offline   Reply With Quote
Old 10-12-2006, 11:46 AM   #14
rob92xj
1992 XJ Cherokee
There is only one filter on the 2.4L/3.7L KJ's and its in the tank...get a real service manual with the correct info.
Sorry for the slight bash on the Chiltons manual but there info is not always right.
The only KJ's with an external filter is the 2.8L CRD.
Glock Forum
