front end noise - JeepForum.com
post #1 of 3 Old 06-01-2014, 08:06 PM Thread Starter
hckrach
2005 KJ Liberty
front end noise
I have an 05 Liberty Renegade, and have recently experienced a front end noise. When I am driving slowly and turning, like out of a driveway, I hear this squeaking type noise, that I can also hear at slow speeds with the windows down, like when driving over the slightest of bumps, like when pulling in and out of the garage. I experimented a little bit, and hear the noise when I turn the steering wheel, when I am stopped. The noise disappears, somewhat, after driving the Jeep for a little bit.
When looking under the front end, I cannot see anything obvious going on. I checked both tie rod ends, along with the upper and lower ball joints. I do wonder if one of the ball joint grease boots is low, just based on the noise, but since I cannot service them, it would require replacement. I will have my brother help me tomorrow check, so he can turn the wheel, while I look at what is going on, but I just wanted a preliminary check with you guys.
In addition, over the past several weeks, there has been a slight vibration (not a death wobble, just enough to be annoying) at highway speeds. It is in need of an alignment, and was hoping that would correct it, but I now wonder if the vibration is related to the squeaking noise from the front end,
Thanks in advance!!
hckrach is offline
post #2 of 3 Old 06-02-2014, 07:52 AM
KJRad
2002 KJ Liberty
i bet its the u-joints on the drive shaft, sounds exactly like what my kj was doing.
KJRad is offline
post #3 of 3 Old 06-02-2014, 10:38 AM
tommudd
2004 KJ Liberty
Check sway bar bushings as well , they will squeak over bumps etc
MUDD'S MOTORSPORTS
04 KJ JBA 4 INCH COILOVER LIFT
03 KJ JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
