Front drive shaft - JeepForum.com
post #1 of 19 Old 07-02-2009, 06:29 AM Thread Starter
r_unda
r_unda's Avatar
Front drive shaft
My dad’s 2004 liberty front drive shaft broke (Don’t know where or how since he is in another country). He told me that the part number is 52111596AB. I found a replacement part on EBay but the last letter on the part number is different, this one reads 52111596AA. Can he still use it? If not where can I find a relative inexpensive front drive shaft? They are charging him $800 just for the part over where he is at. I found an OEM one for around $400, and the Ebay one is around $250.
Thank you,
Raul
r_unda is offline
post #2 of 19 Old 07-02-2009, 08:28 AM
djui5
2004 KJ Liberty
Tell him to get a new drive shaft with U-joints. Those CV's are just going to break again I have an 04 too.
djui5 is offline
post #3 of 19 Old 07-02-2009, 03:33 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The letters at the end are revision nomenclature, AA being an earlier rev than AB, etc. Although normally they are backward compatible I generally wouldn't trust used CV joints.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 19 Old 07-02-2009, 03:47 PM Thread Starter
r_unda
r_unda's Avatar
Thanks for the info guys!
The one on Ebay says its Remanufactured. Here is the link:
http://cgi.ebay.com/ebaymotors/Jeep-...Q5fAccessories
What do you guys think?
My Jeep isn't getting older, it's getting newer part by part
2011 WK2 HEMI 4x4 Overland
2007 WK CRD 4x4 Limited GDE Tuned
1998 TJ SE
1973 CJ5 - YJ OME 2.5" lift, 33" tires
1951 Willys truck
r_unda is offline
post #5 of 19 Old 07-02-2009, 04:12 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
With a feedback of 688 and a 99.2% positive they sound like good guys to deal with. Personally I've had very good luck on eBay. They suggest contacting them and I certainly would in this case. Give them all of the info that you have and see what they say.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #6 of 19 Old 07-05-2009, 01:28 PM
scottunangst
Thank you,
Raul
'04 liberties used two different transfer cases, they are not interchangable so mite use different length drive shafts
scottunangst is offline
post #7 of 19 Old 06-25-2010, 08:47 PM
Damon1122
go to All Drive Lines - Pictures
new serviceable front liberty drive shafts
Damon1122 is offline
post #8 of 19 Old 06-25-2010, 09:05 PM
tjkj2002
2002 KJ Liberty
Do not buy,the wrong type of driveshaft for the front of a KJ,will cause issue in the long run.
Read up.............
Pirate4x4.Com - Extreme Four Wheel Drive
tjkj2002 is offline
post #9 of 19 Old 07-04-2010, 02:28 PM
dagooaz
2004 KJ Liberty
Hey tjkj, I'm admittedly not a drive shaft expert, but why would the drive shaft with the u joints be bad? I read a lot of the article, and maybe I missed it, but I didn't see anything about why it would be bad.
2004 Jeep Liberty Sport 4X4
dagooaz is offline
post #10 of 19 Old 07-04-2010, 02:37 PM
jimymc
2003 KJ Liberty
The AA and AB are interchangeable. I had an AB shaft and changed it out for an AA OEM and it worked just great. The online MOPAR wholesale parts place said that they are essentially the same. They are both 16.5 inch shafts. I paid a little more for the OEM shaft $470 but I figure if the original OEM lasted 120K miles then another 120K for the difference in price from a questionable source is worth it.
jimymc is offline
post #11 of 19 Old 07-04-2010, 02:51 PM
tjkj2002
2002 KJ Liberty
It's called pinion angles.The front of the KJ does not fit any of the u-joint driveshaft criteria thus will cause issues.Also why it came with CV joints instead of u-joints due to space limitations.
tjkj2002 is offline
post #12 of 19 Old 07-04-2010, 05:09 PM
dagooaz
2004 KJ Liberty
Groovy, thanks for the quick response.
dagooaz is offline
post #13 of 19 Old 07-04-2010, 08:31 PM
jamesdart
guy has 7 posts all linking to the company. no other types of posts. doesnt even back up his product when told its no good for libertys just keeps posting the link.
jamesdart is offline
post #14 of 19 Old 09-30-2010, 07:24 AM Thread Starter
r_unda
r_unda's Avatar
Well you were right. I just got an email form him and it broke again. He wants to try to do a conversion to u-joints.
Here is where I need your guys help. He is in Venezuela. There is no way I can get him a new conversion u-joint drive shaft over there without paying a super high shipping fee and a ridicule import tax. A replacement drive shaft costs about $800 only if he can find it (you cant find anything over there these days)
If you have pictures of the conversion, please post them here. Also if you can give me the driveshaft length would be great and whatever other info he would need to know in order have it custom made over there.
Thank you so much guys!
1998 TJ SE
1951 Willys truck
r_unda is offline
post #15 of 19 Old 09-30-2010, 04:56 PM
CATCRD
2005 KJ Liberty
Here is one that I saw. I can't say if there were any problems with vibration or not. The owner kind of disappeared off the boards. No measurements either. The front end is still a CV obviously.
CATCRD is offline
Jeep Liberty '03 Front Drive Shaft Replacement Whitelightnin92 KJ Liberty Forum 11 02-08-2013 05:00 PM
Arising CV’s & Drive Shaft issues for models 02-04. READ Jeep dawg KJ Liberty Forum 5 06-25-2010 09:04 PM
2005 Rear drive shaft flange bolts MakoML KJ Liberty Forum 1 12-21-2009 09:49 PM
Front drive shaft squeaking Clockworkorange KJ Liberty Forum 8 10-05-2009 01:15 PM
drive shaft suggestions pajeep KJ Liberty Forum 1 11-12-2006 08:20 AM
