Found ATF+4 at Walmart - Page 2 - JeepForum.com
post #16 of 24 Old 09-11-2006, 08:57 PM Thread Starter
RFCRD
Originally Posted by dcxman
Amen brother. If anyone is running 15w40 syn or non in a CRD on a regular
basis, I would like to hear of their experiences.
I want to go with 15W40 Rotella but will use 5W40 atleast one more time as I have 2 gal. of it on the shelf. I still have some minor oiling from the turbo seals with 0W40. Once DC's oil consumption test is over, 5W40 goes back in. If that doesn't stop the oiling, will try the 15W40. This is the only vehicle I've owned (gas or diesel) where the OEM was this anal about oil standards (and got it wrong on the standard). Even my dealer is questioning the CF vs. CI-4.
RFCRD is offline
post #17 of 24 Old 09-12-2006, 06:39 AM
dcxman
2006 KJ Liberty
I have noticed that while driving at night with lighting behind me, that when I
accelerate hard that a fair amount of particulate matter is exhausted.
Is that normal, or could that be evidence of oiling past the turbo seals.
I really can't see it in the daytime.
dcxman is offline
post #18 of 24 Old 09-12-2006, 09:09 AM Thread Starter
RFCRD
That is a real good indication. If you inhale motor oil vapors you will get either soot (if it burns) or oily exhaust which in theory will get burned in the catalyst which will also make soot. Keep in mind that VGT blades rotate (change pitch) and are subject to oil/sludge coking causing them to stick/malfunction.
The best way to tell is you are getting oil through the seals:
1). Eliminate the CCV as a cause (install a Provent or just open vent).
2). Thoroughly clean your CAC hoses to the original bright red condition. Don't forget to clean the rubber boot from the airbox to the turbo. A little biodiesel and a dish brush cut right through the oil without damaging the silicone lined hoses. Ether works well too.
3). Reassemble and drive the vehicle. Over time, monitor the CAC hoses, especially the turbo to the intercooler hose for fresh oiling. The intercooler to engine hose will continue to foul until the all the oil is purged from the intercooler.
I have mine down to a small amount in the first 4 inches of the CAC hose past the turbo. If you do find oiling, need to find the reason (filter constriction, light weight oil, defective turbo, etc..). Finally, forget about arguning the point with DC. They will tell you it's from the CCV and that it's normal regardless of the sorce or damage it will cause over time.
RFCRD is offline
post #19 of 24 Old 09-12-2006, 10:23 AM
dcxman
2006 KJ Liberty
Thanks for the info. FYI the only 0w40 oil run through my CRD was what came
from the factory. I've mostly run 5w40.5w30 and15w40 in descending order.
Also since no one answered my thread, have you seen a need to adjust your emergency brake? I have to push mine
almost all the way to the floor to engage.
dcxman is offline
post #20 of 24 Old 09-12-2006, 12:25 PM
BVCRD
My e brake seems to hold just fine the way it is. It isn't on the floor though.
2006 Jeep Liberty Sport CRD
BVCRD is offline
post #21 of 24 Old 09-12-2006, 06:33 PM
dcxman
2006 KJ Liberty
Yes, I forgot my little smiley face. In fact, I like it where it is.
dcxman is offline
post #22 of 24 Old 09-12-2006, 08:04 PM
BVCRD
Me too. Got more room for my size 15s.
BVCRD is offline
post #23 of 24 Old 09-13-2006, 08:04 AM
dcxman
2006 KJ Liberty
Where's your smiley face? I don't think you were talking about wheels.
dcxman is offline
post #24 of 24 Old 09-13-2006, 10:34 AM
BVCRD
OK, now that's funny. No, talking about some other kind of treads. Anybody who says the Libby is too small for them I say BS! If I can get shoehorned in there, so can they.
BVCRD is offline
Found Leak at Rear Differential Box tracker57 KJ Liberty Forum 0 11-05-2008 11:25 AM
walmart has 0w40 mobil one in stock now 4.0v8eater KJ Liberty Forum 27 08-26-2006 10:38 PM
Ok CRD oil change interval and oil questions walmart specific, which oil filter? 4.0v8eater KJ Liberty Forum 3 05-24-2006 08:45 PM
Found a CRD... anyone want to test drive? brewcider KJ Liberty Forum 14 05-14-2005 02:59 PM
I found a honest stealership belezeeubub KJ Liberty Forum 5 05-07-2005 10:20 AM
