Flashing Check Engine Light w/ Loss of Power - JeepForum.com
post #1 of 10 Old 04-11-2016, 08:20 AM Thread Starter
ACM423
2016 JK Wrangler
Need some advice, went wheeling on the 9th and on the trip home I noticed my check engine light flash and the Jeep didnt seem to know what gear it wanted to go into. Only happened once though so I didn't think much about it.
On the 10th, I went to go get groceries and around 1.5k and 2k rpm the check engine light flashes and I loose power. Didnt have any problems while wheeling, was in 4low and first and second gear the whole time. Didnt smack the undercarriage on anything or bounce around really hard. Any ideas what could be wrong? I will be taking it into the garage next weekend if the problem persists. I wont be doing much driving during to two weeks leading up to going to the garage.
ACM423 is offline
post #2 of 10 Old 04-11-2016, 02:40 PM
02blue
2005 KJ Liberty
Probably not much anyone can tell you until you get the codes read. Flashing CEL usually means something bad is happening to the cats. Sounds like it could be a pretty bad misfire. Bad O2 sensors can cause these types of misfires and the hesitation that may feel like the tranny. I wouldn't mess with anything until you see what codes are stored. Just in case the CEL and strange "tranny" sensation aren't related, is the tranny fluid level okay and has it been serviced recently?
"Hey, ya never know til you try." Kurt Russell-Big Trouble in Little China
02blue is offline
post #3 of 10 Old 04-12-2016, 10:58 AM
tjkj2002
2002 KJ Liberty
Flashing MIL means that cat damage is taking place.Never drive it with a flashing MIL.
Without codes it's a 1 n 4000+ guess s what is wrong.
tjkj2002 is offline
post #4 of 10 Old 04-12-2016, 11:25 AM Thread Starter
ACM423
2016 JK Wrangler
Okay, so I got the codes:
P0300 Random Misfire
P1129
P0152 O2 Circuit High Voltage (Bank 2, Sensor 1)
P0157 O2 Circuit Low Voltage (Bank 2, Sensor 2)
P0158 O2 Circuit High Voltage (Bank 2, Sensor 2)
Guy at AutoZone said its probably just water in my O2 sensor and to check my wires to make sure they're dry since I went through some fairly deep water.
The Jeep was just serviced the weekend before with all fresh fluids and filters as well as a full inspection.
ACM423 is offline
post #5 of 10 Old 04-12-2016, 05:29 PM
tjkj2002
2002 KJ Liberty
P1129
You will want to change the diff fluids again and check the trans and t-case for water.
tjkj2002 is offline
post #6 of 10 Old 04-30-2016, 08:58 AM Thread Starter
ACM423
2016 JK Wrangler
I replaced both Bank Two O2 sensors and the problem was solved for a couple days...I went back and had them pull codes and got the engine misfire and the Bank2, Sensor1 O2 sensor which I just replaced. The engine starts misfireing at roughly 2.1k rpm. Up until then it runs perfectly fine. At about 3k the engine will stop misfireing and go back to normal operation. This is only observable while driving, sitting still and rev the engine up it has no problem. The said it could be spark plugs, so I ordered a new set of plugs for it and will be getting them wednesday. The plugs havent been changed since Ive owned it and I have no idea if they had been changed before I got it, so theyre probably due to be switched out anyways.
ACM423 is offline
post #7 of 10 Old 04-30-2016, 02:21 PM
streetglideok
2005 KJ Liberty
Please understand, vAutozone does not possess any ability to diagnose problems at all. Take the info they give you, and use it for toilet paper. If you haven't replaced the plugs in the last 30k miles with NGK copper plugs, then you need to start there. If you replaced the O2 sensors with Bosch, you need to install the right ones(ngk/ntk, densor, or mopar). If you got your parts at autozone, then that's likely a contributing problem
streetglideok is offline
post #8 of 10 Old 05-05-2016, 02:44 PM Thread Starter
ACM423
2016 JK Wrangler
Okay, i finally solved my misfire problem. Replacing all the plugs did the trick. 82k miles and they had never been replaced. Replaced them with some MSD performance plugs.
ACM423 is offline
post #9 of 10 Old 05-05-2016, 07:06 PM
streetglideok
2005 KJ Liberty
Oh boy, some people never learn. Remember that part up above when I said, NGK is the oe plug? Lots of issues using all the new fangled fancy overpriced plugs in these engines, and misfires, etc returning later. The only thing performance about those plugs you got, is in how fast they emptied your wallet. Parts store told you to try these, didn't they?
post #10 of 10 Old 05-14-2016, 01:22 PM Thread Starter
ACM423
2016 JK Wrangler
I had actually already ordered them before you had posted your comment. I had looked them up on Summit Racing and they had good reviews so I went with them.
ACM423 is offline
