Fan / Blower switch only works on high - JeepForum.com
post #1 of 4 Old 09-29-2007, 09:34 AM Thread Starter
skates04
skates04's Avatar
I just picked up a 03 Liberty, The blower/fan switch was working fine, but now its only working on the highest setting, I recall on my wrangler this happend I replaced the resistor pack for the switch that was located under a kick panel under the passenger side dash, I was wondering if its in the same location, as the wrangler, and if the liberty's use the same crappy resistor pack, or if it would be somthing else, Im new to the whole liberty thing, but so far I love it!
skates04 is offline
post #2 of 4 Old 09-29-2007, 10:19 AM
merlinTec
merlinTec's Avatar
Hi
It will be the same. Drop the glove box down and you will see it. 4 wires 2 screws hold it in. test with an ohm meter and you should have circuit between all the pins. Or just replace it’s 99% going to be that.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #3 of 4 Old 09-29-2007, 03:34 PM Thread Starter
skates04
skates04's Avatar
Thanks for the reply, I got a resistor pack on order, sounds like it should be an easy fix, on the wrangler you pretty much have to do a head stand infront of the passenger seat to get to it
skates04 is offline
post #4 of 4 Old 10-03-2007, 08:04 PM Thread Starter
skates04
skates04's Avatar
Replaced the resistor pack today, it took 10 minutes and cost me 12 dollars, problem solved!
skates04 is offline
Blower motor or switch going bad? upnorthbacon KJ Liberty Forum 25 01-28-2011 07:58 AM
Fan only works on level 4, why? delliup KJ Liberty Forum 3 10-13-2009 08:24 PM
Heater/AC Blower only works on High Sevenfootman KJ Liberty Forum 6 12-20-2008 05:58 AM
2002 Liberty blower works but will not produce hot air kdjf4 KJ Liberty Forum 2 12-03-2008 03:48 PM
Blower Motor Only Works On 4 HARDEIGHT KJ Liberty Forum 10 01-09-2008 05:31 PM
