Exhaust(?) drone only when driving not parked - JeepForum.com
post #1 of 8 Old 06-06-2014, 12:20 PM Thread Starter
Tombo_ontario
2002 KJ Liberty
I have had this issue for a little while, ever since installing an aftermarket muffler. Now I know, obviously, that the muffler is louder than stock, but not by much...and it gives more growl. However, I've noticed that at right around 1500rpm there is a nasty drone while driving around. This is especially irritating as it tends to be right at city cruising speed. This is not the case though if I rev up through the rpms while stationary...
So obviously it is being caused when the jeep is under load or perhaps there is something else that is resonating only while moving though?? The muffler itself gives a nice note while idle...definitely not loud at all...and when I rev up while stationary (parked), that too is a pleasant sound...not too loud at all...
Anybody run into this problem? Any suggestions? My next step may be to just try and tighten every nut and bolt I find on the underside...who knows lol
Tombo_ontario is offline
post #2 of 8 Old 06-06-2014, 07:29 PM
tjkj2002
2002 KJ Liberty
Revving in park will not have the same volume out the tail pipe since the engine is under almost no load or airflow(of passing air as your driving) as actually driving.
Gotta live with it or find a more stock replacement type.
tjkj2002 is offline
post #3 of 8 Old 06-07-2014, 04:28 AM
kirksjeep
Switch to a Dynomax. Affordable, and no drone.
1992 YJ Sahara- 4.5" RE XD, 1" BL, 1" MML, 35" BFG MT, 8.8 w/Aussie, D30 w/Ten Factory shafts/ Aussie, 4:10 gears, Soild Diff Covers, SYE, CV Drive shaft, OBA, Flowmaster Super 44,, Custom head pipe, Super Chip, Boared out TB, Rock It Intake , Goferit Tie Rod Flip, 99+ intake manifold/Steering pump, custom front/rear bumpers,Hand Throttle, Hurst Shifter, Smitty Built sliders , 6" TJ flairs, Kilby belly up skid, Quadratech 9K winch, ZJ PS cooler. 01 XJ Sport-2" lift, 31x10.50 MT/ 02 Liberty 2" Lift
kirksjeep is offline
post #4 of 8 Old 06-07-2014, 06:29 AM Thread Starter
Tombo_ontario
2002 KJ Liberty
Thanks guys...ya it just hit me that it's chambered and I've read bad things about them droning like hell. I'll see if i can pick up a dynomax or maybe even a magnaflow perforated core on the cheap side.
post #5 of 8 Old 06-07-2014, 05:10 PM
02blue
2002 KJ Liberty
Just put a Dynomax High flow on my 4.0L Ranger and it sounds real nice. Ultra flo Welded.
"Hey, ya never know til you try." Kurt Russell-Big Trouble in Little China
02blue is online now
post #6 of 8 Old 06-07-2014, 07:48 PM Thread Starter
Tombo_ontario
2002 KJ Liberty
Anyone have a specific dynomax or magnaflow part number for the 3.7 liberty? Just wondering if I can get away with a shorter muffler than stock or if it's best to get same size...
post #7 of 8 Old 06-07-2014, 10:04 PM
tommudd
2004 KJ Liberty
Can't remember the number I have, its about half the length of a stock one, just found one with 2.5 in and out and offset/center
04 KJ WITH JBA 4 INCH COILOVER LIFT
03 KJ WITH JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #8 of 8 Old 06-08-2014, 12:00 AM
kirksjeep
I bought the Dynomax muffler and tail pipe at the same time from Jegs. They used to sell it as a kit, but now you have to buy both pieces separate. The only other piece you would need is the muffler clamp for between the muffler and cat.
