EVAP System Leak, how do you find it? - JeepForum.com
post #1 of 6 Old 09-29-2006, 09:00 AM Thread Starter
ej's tj
ej's tj's Avatar
Ok, so I got stupid yesterday and bought the hand held code reader from the auto parts store to read codes in my 2002 Liberty ( there was not anyone there that could take 5 minutes to walk outside and read the codes for me so I got mad and just bought the $280 computer ). It states there is a "small leak in the EVAP system". I have a basic level of mechanical aptitude and can usually fix most minor things, but for the life of me I can not find a hose off or any holes that would cause this error code. Also, I do not see anything that resembles what I think a "charcoal canister" should look like. I do not see anything that resembles a 2 lb. coffee can with vacuum lines coming out of it.
So my questions are these: 1. How does one go about finding said leak. 2. where in the world is the evap canister.
I actually have three Jeeps, my wife's Liberty, a Cherokee and my Wrangler. It is a pain when two of the three have the same problem......
2005 Unlimited Rubicon bright red, wet okole, 2 1/2" (more like 3"+) HD OME 1 1/4" JKS BL, JKS Discos, 1" JKS MML,28575R16 BFG MTs, Custom HD rear bumper, 2 year old Akita,
9500 lb. milemarker winch, kilby gas tank skid, home made rear bumper and tire carrier, lite dot taillights, more to come!!!!!!
Integrity is a rare find!
ej's tj is offline
post #2 of 6 Old 09-29-2006, 07:16 PM
VTNomad
Gas cap
Check and make sure your gas cap is on tight. This has been known to cause the issue, and it's the easiest thing to fix. Let us know if that works.
2012 Black Jeep Wrangler Rubicon 2-door
VTNomad is offline
post #3 of 6 Old 09-29-2006, 10:37 PM Thread Starter
ej's tj
ej's tj's Avatar
I will try that tomorrow, thanks for your help!
ej's tj is offline
post #4 of 6 Old 09-29-2006, 11:31 PM
Matt400
The last evap leak I found on a Wrangler was under the hood.
Take a look between the drivers fender and manifold for a green colored cap attached to black lines. Thats the evap test port, The rubber hoses that connect the plastic pipes near there will crack and cause the leak.
Many times you can cut the bad end off and re attach but if not then a replacement hose is needed.
Dont put an air hose on that test port cuz more than 1 psi can cause grief.
On your wifes Liberty take a look above the rear axle, again there are rubber hoses that attach the plastic pipes to the charcoal canister, those hoses will split there on that model.
Matt400 is offline
post #5 of 6 Old 09-30-2006, 09:27 AM
jeepjeepster
I believe the charcoal filter is under the rear of the kj somewhere. Most likely your leak is under there some where since thats where all the evap crap is on the kj.
jeepjeepster is offline
post #6 of 6 Old 09-30-2006, 11:41 AM
rob92xj
1992 XJ Cherokee
There is a 1/4" hose in front of the rear axle that goes to the fuel tank which is the usual place to find leaks on a KJ.
rob92xj is offline
P0455 Error EVAP Emissions Control Large Leak 2002 Jeep Liberty? MKaye02 KJ Liberty Forum 22 03-16-2016 09:24 PM
Check Engine Evap Sensor '03 3.7L Redrum257 KJ Liberty Forum 1 01-04-2010 06:41 PM
p1775 Solenoid switch & p0456 evap leak problems theabacus KJ Liberty Forum 1 05-17-2009 11:29 PM
EVAP system code & canister location noodlestsc KJ Liberty Forum 2 08-04-2008 09:53 AM
check engine:small emission system leak El_Jeepo KJ Liberty Forum 5 07-22-2008 09:42 AM
