EVAP system code & canister location - JeepForum.com
post #1 of 3 Old 08-01-2008, 10:23 AM Thread Starter
noodlestsc
My wife's 02 Liberty keeps pulling the P0442 code for the evap containment system. At first I thought it was the gas cap. Tightened it up, cleared the code, but a few days later it popped back up...Second time around replaced the gas cap, cleared the code and again a few days later it popped back up.
I haven't really took a look for it yet, but where is the charcoal canister on the Liberty so I can start the tedious task of hose leak detection?
>>I'd rather be out wheeling in my Jeep thinking about God than sitting in church thinking about my Jeep.<<
'04 TJ. RE 4.5 superflex (3.5 springs), 1"BL, 32x11.50x15 Kuhmo Venture MTs, JKS discos, skidded, Powertrax No-Slip up front, winch, SYE, Tom Woods shaft, soon to be homemade flat TC skid
noodlestsc is offline
post #2 of 3 Old 08-02-2008, 05:38 PM
CaBowhunter
1978 FSJ Cherokee
I had the same problem , Then the rear pinion seal started to leak and while replacing it I noticed a molded hose right above the rear axle going in to a evap box was spilt . I replaced the hose and cleared the code and it has not repeated. Hope this helps.
Randy
CaBowhunter is offline
post #3 of 3 Old 08-04-2008, 09:53 AM
tony673
Originally Posted by CaBowhunter View Post
I had the same problem.....I noticed a molded hose right above the rear axle going in to a evap box was spilt . I replaced the hose and cleared the code and it has not repeated. Hope this helps.
Randy
My wife's Liberty had the same thing happen. It took me months to figure it out because the crack was pretty small and not easily seen. We hooked it up to a line leaker tester thing (not sure of the actual name, but it forces smoke into the lines to see where it leaks out) and sure enough, that's where it was coming from.
07 Wrangler Unlimited Rubicon
02 Liberty Sport
<---- AR15, AK Accessories
tony673 is offline
P0455 Error EVAP Emissions Control Large Leak 2002 Jeep Liberty? MKaye02 KJ Liberty Forum 22 03-16-2016 09:24 PM
CEL - evap sensor - repeatedly - common issue? LibertynJustice KJ Liberty Forum 9 05-01-2013 05:21 AM
Check Engine Evap Sensor '03 3.7L Redrum257 KJ Liberty Forum 1 01-04-2010 06:41 PM
p1775 Solenoid switch & p0456 evap leak problems theabacus KJ Liberty Forum 1 05-17-2009 11:29 PM
EVAP System Leak, how do you find it? ej's tj KJ Liberty Forum 5 09-30-2006 11:41 AM
