Evap Purge Solenoid & Natural Vacuum Leak Dectector Assembly - Need to Replace.HELP - JeepForum.com
post #1 of 7 Old 12-04-2010, 03:32 PM Thread Starter
ilovekale
The check engine light was on on my Jeep Liberty 2004, 3.7 Liter.
I took to the dealer and they said:
"P0040 General Evap System Failure, found purge solenoid not holding vacuum and leak detector not switching properly. Recommend replacement of evap purge solenoid and natural vacuum leak detector assembly"
They wanted 400 to replace the purge solenoid, a job that took me 5 minutes and a $40 part... however..
I replaced the purge solenoid and the light is still on. Can someone please tell me what the "Natural Vacuum Leak Detector" part number is. Is this a separate part. The guy at the dealer part shop said it was all the same and I just needed the purge solenoid.
I have a feeling that the "natural vacuum leak detector" is something different. So can someone tell me the part number for this part.
Thank You
Philip
ilovekale is offline
post #2 of 7 Old 12-04-2010, 03:56 PM
DaveJKJ
2005 KJ Liberty
Did you clear the code after you replaced the purge selenoid? If you didn't then maybe that's why the MIL is still on?
Lifted, Skids, Hooks, Rails, Trail Rash..
War Veterans Jeep Group #31
Black Jeep Society #217
DaveJKJ is offline
post #3 of 7 Old 12-04-2010, 09:22 PM
richd
2008 KK Liberty
Thank You
Philip
PO040 is not General Evap System Failure it is Oxygen Sensor Signals Swapped Bank 1 Sensor 1 / Bank 2 Sensor 1.So you either mistook the code,or you have a differant problem.The answer to your question is,the Natural Vacuum leak detector is differant then the Purge Solenoid.The Detector is located on the front of the fuel tank.The part # I have is 04891525AB@118 list price.Double check if you call for part that thats the right number.I think the code you have is PO440-Evap Sys Perf
richd is offline
post #4 of 7 Old 12-05-2010, 06:31 PM Thread Starter
ilovekale
Yes, I mistyped the code, my apologies it is P0440.
OK, so I will look for that part. Weird because I though it was two parts when picking up the car and two people at the dealer said it was only one part.
To answer the reset, I disconnected the battery for 5 minutes and the light went out, came back on a couple of days later.
Will it cause problems not to replace this immediately? I will replace it soon though.
Thank you for the help.
Philip
post #5 of 7 Old 01-15-2011, 08:57 AM
Urkel
Why disconnect the battery and wait 5 minutes? That resets the computer... right? What I started doing was disconnecting the three harness connections on the computer. If you do that with the engine running, you will see that no matter which one you disconnect the engine will shut down. So, if you disconnect all three with or without the engine on, it will reset it. You will then have to drive 40 to 60 miles for the computer to find faults. I would say, check the gas cap. I had 3 codes. I found one hose on the solenoid was starting to fray, I changed it. Blow out that filter on the small round canister. My jeep was fine. After using the gas cap at autozone, I returned it because it would set off a code. So, I got the Stant Gas Cap from my friend's store. I haven't had ANY problems in 6 months. Also, make sure you check that the gas cap is tight, when you get gas. That is another cause of the problem.
I could have paid $200 to have someone detect the leak with a smoke test, I could have replaced every part from the canister to the valve and wasted $500. But I did a few things that costed less than $50 and solved my issues.
Urkel is offline
post #6 of 7 Old 01-15-2011, 07:25 PM
tjkj2002
2002 KJ Liberty
Never disconnect the PCM while the engine is running or with the battery connected,sure fire way to fry the PCM.
tjkj2002 is offline
post #7 of 7 Old 01-16-2011, 06:24 AM
Urkel
I haven't had a problem. I've done it several times. I have shut the key off, before connecing it. It actually corrected some electrical issues. I doubt it will fry it. With the ignition off, the computer isn't on. And if so, jumping another car will do more damage! The cables spark when they connect. But, if you say so! I'll ask my friend that works on Lamborghini's.
Urkel is offline
P0455 Error EVAP Emissions Control Large Leak 2002 Jeep Liberty? MKaye02 KJ Liberty Forum 22 03-16-2016 10:24 PM
What tools are needed to replace a tail light assembly?? OtsiderCherokee KJ Liberty Forum 0 07-16-2010 01:37 PM
05 CRD Stalling, 'Vacuum Leak' CEL Code abhester3 KJ Liberty Forum 7 08-19-2009 12:18 PM
p1775 Solenoid switch & p0456 evap leak problems theabacus KJ Liberty Forum 1 05-18-2009 12:29 AM
EVAP System Leak, how do you find it? ej's tj KJ Liberty Forum 5 09-30-2006 12:41 PM
