Error code help - JeepForum.com
post #1 of 2 Old 07-05-2013, 06:59 PM Thread Starter
Jettster
Error code help
Long time lurker and Jeep owner. My wife and I just got back from a week vacation and she started up her 2005 KJ. Her engine light came on, flashed a few times and we turned it right off. Our mechanic is backlogged and we don't want to drive it to our other reliable mechanic 45 minutes away. I checked the codes and P0035 and P0039 popped up. Both are crank error codes, Crankshaft position sensor A Circuit Performance and Crankshaft position sensor intermittent. We had a new transmission put in over the winter, but other than that, her car has been reliable.
Has anyone encountered these codes before, and if so, what was the repair/result. It was running/idling rough and I'm concerned it may be a big repair.
Thanks in advance.
Jettster is offline
post #2 of 2 Old 07-05-2013, 08:07 PM
streetglideok
2005 KJ Liberty
Can be a faulty crank sensor, and/or faulty cam sensor. Without proper tools, you're guessing which one, if either of them is the culprit. Yes they are crank sensor codes, however, Chryslers are well known for having confused powertrain modules, and labeling the wrong sensor as suspect. Best source for new ones,.... dealer.
streetglideok is offline
