engine oil recommendations - JeepForum.com
post #1 of 22 Old 05-12-2012, 11:09 AM Thread Starter
chrisusvi
I have an '02 Jeep Liberty with about 43,000 miles. I live and drive in a climate that is warm to hot year round. The terrain is quite hilly too.
What is a good engine oil for this type of climate? Could I upgrade to MOBILE1 without harming the engine?
chrisusvi is offline
post #2 of 22 Old 05-12-2012, 11:31 AM
wendell
1987 YJ Wrangler
Mobil 1 won't hurt an engine, it will help it, I've used mobil 1 for years in everything, even my lawn tractor. Mobil 1 is in my 07 liberty as we speak. The only thing I don't have mobil 1 in is my 87 wrangler, because of the abuse it gets I run amsoil in the whole drivetrain.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #3 of 22 Old 05-12-2012, 12:18 PM Thread Starter
chrisusvi
What is the best weight?
post #4 of 22 Old 05-12-2012, 12:28 PM
Lafever25
Agreed ^^^ Mobil 1 is definitely one of the best synthec oils out there.. I am currently trying the purple stuff... 5w30 is manufacturers recommendation, so I'd stick to that or go heavier during hot times like June, July, August... 10w30 or 40.
Lafever25 is offline
post #5 of 22 Old 05-12-2012, 05:11 PM Thread Starter
chrisusvi
With Mobile 1, do you have to change the oil as often as conventional oils?
post #6 of 22 Old 05-12-2012, 05:17 PM
04liberty4x4
I'm running 5w30 Valvoline Syn Power full synthetic
2004 Jeep Liberty 4x4 v6, Cold Air intake, projector lenses 35w 4300 HID kit
04liberty4x4 is offline
post #7 of 22 Old 05-13-2012, 07:58 AM
95BadBoy
If you really want to know the condition of your oil, and whether you can run an extended oil change interval - get an oil analysis done from any of the oil testing labs like Blackstone labs or another company. You mail in a sample and they send you the results.
It is not expensive, and you will not be going on here-say or by what someone else is doing or experiencing with their rig. Just an idea for ya .
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #8 of 22 Old 05-13-2012, 09:02 AM
streetglideok
2005 KJ Liberty
Personally, I'm running 5w30 Mobil1 and going every 5k miles, and using a wix filter. Even in the extreme heat of the american south, I still ran 5w30 with no issues, in modern engines. One thing I should add, oils dont vary by viscocity alone when looking at different weights of oils. Their performance and chemical makeups can be different, and be designed for different uses. Ford and their 5w20 is a good example. There isnt alot of difference between 5w20 and 5w30 oils as far as viscocity goes, if any, but the additives can be alot different, and the 5w20 that meets the Ford spec, seen on Mobil1 bottles, as well as the Motorcraft stuff is a step up from 5w30. Theres information out there on the subject, Fords sticking oil control rings on the pistons, and using 5w20 to free them up.
streetglideok is offline
post #9 of 22 Old 05-14-2012, 04:43 AM Thread Starter
chrisusvi
When using Mobil 1, does the type of oil filter need to change too?
post #10 of 22 Old 05-14-2012, 07:33 AM
Lafever25
Synthetic oils are simply better quality oil. Good measure is to check your oil dipstick at about 3k, depending on how hard you drive during that period. If its mainly highway than change the oil at 5k, mix driving I'd say around 4k. If your doing alotta off-roading, high revving, racing or towing I'd say change at about 3/3500 miles.. It's up to you to know your driving habits and your jeep condition. With that said, a higher quality oil filter will be able to trap more contaminants than a cheapo filter, still I'd change it ever oil change but I have heard people changing it every other, depending on how good of a filter they are using. Any filter is fine, at 46k you shouldn't be finding anymore shavings as your engine should be well broken in already... There were times I reused a filter when I saw how clean my old oil was but usually I change it everytime. Hope that helps
post #11 of 22 Old 05-14-2012, 01:48 PM
jp7794
2006 KJ Liberty
jp7794 is offline
post #12 of 22 Old 05-15-2012, 06:51 AM
tjkj2002
2002 KJ Liberty
Originally Posted by Powerslave View Post
Using Synthetic, you don't need to change every 3-4K, that's the whole idea for using it, less waste from used oil. Syn will last 25K easy. If you're gonna change it every 3-4K, then just use DINO oil, it's cheaper, and what the factory calls for.
With synthetic; I change mine twice a year, that's it, and I put 15K or better a year on it.
Mobil 1 says 15,000 miles and Amsoil says 25,000 miles between changes.
You'll spend more money changing DINO oil 3 times -vs- Synthetic once in that time frame.
Please go 15k or 25k on your syn oil,report back when you need a new engine so we all can get a good luagh at your expense
tjkj2002 is offline
post #13 of 22 Old 05-15-2012, 03:05 PM
03libby
2003 KJ Liberty
Just a quick question from a regular joe...when going 15k between oil changes do you have to top off the oil? I've read on here and other sites (not just for the jeeps) that people are burning oil and having to add it in just a 3k oil change. Just a question
03 Jeep Liberty Limited
Cragar soft 8's
BFG A/T TA's
03libby is offline
post #14 of 22 Old 05-15-2012, 04:08 PM
tjkj2002
2002 KJ Liberty
I am reporting back, and I don't need a new engine. SO, I am the one laughing, at YOU, and I mean RIGHT at you, once more, heh heh heh. You call me out all the time, and you're always wrong. I got the Jeep with 56K miles, 'round there somewhere. Got 96K+ miles on it now, FOUR oil changes in all, all with 100% Synthetic. How do I keep beating YOUR system? Would you like to explain that? I mean, you're the expert, right? RIGHT? Don't say you're not an expert, that would only tell me what already know, and I would wholeheartedly agree, that you are NOT...
You're system must be one of the most flawed ones on Earth, because I beat the TAR out of it. SO, yeah, I am laughing at you, Again, as I always do when you call me out. I think you need to take another look at the actual physics of your so called "system", because I am way ahead of it.
My Avenger had 153K on it when I sold that, it's STILL on the road, some dude in South Side bought it.. Ran that ABOUT 15K between changes as well. The odds can't be on my side with your "system" if I keep hammering it flat...
PLEASE let me know when you become an expert, otherwise, you should really start each sentence with "I am no expert, BUT:" then it would be much easier to dismiss your bull-droppings.... Something is obvious off with your system, I mean, you keep letting me know what I will need, when I do this, that, or the other, but yet I am just fine.... Seriously, know who you're dealing with, I am much smarter than you, the Government would agree, I wasn't in the USAF because I was an idiot. You a Sailor? Heh Heh...
Love catching idiots lying..............
Your words..............
Might want tro rethink trying to say that I don't know anything about vehicles,I've forgotten more stuff about wrenching then you will ever know in your whole life.
Smart and being in the chairforce have nothing to do with anything you may or may not think you are or not,actually being smart and being in the chairforce don't belong in the same sentance.
tjkj2002 is offline
post #15 of 22 Old 05-15-2012, 08:27 PM
streetglideok
2005 KJ Liberty
I put powerslave on iggy a long time ago, he gives the guys that really know how to work on cars a bad name, sadly. Remember when he actually believed the number of an OBDII code was relevant to how important it was, ie P0401 was more serious then a P0320?
This is funny. With all the bases, including 3 USAF installations in town, Ive learned a few things about the military. Theres a few guys that know something about cars, but there is a ton that THINK they know something, and do a great job at screwing things up. We get the last laugh since we take their money and fix their mess. I somehow believe PS fits in that.
any recommendations Oppcity KJ Liberty Forum 2 01-17-2012 09:48 PM
02 KJ lift recommendations? DaniLaurette KJ Liberty Forum 1 06-08-2010 11:58 AM
Tire recommendations dadoftwo KJ Liberty Forum 13 12-18-2007 09:11 PM
KJ Strut Recommendations? Jeep4Wheeler KJ Liberty Forum 3 12-15-2006 06:46 PM
Tire Recommendations Steven73 KJ Liberty Forum 23 11-18-2004 06:48 AM
