Engine not starting - JeepForum.com
post #1 of 4 Old 07-03-2012, 12:46 AM Thread Starter
Kimiko
2003 KJ Liberty
Engine not starting
I have a Jeep Liberty 2003 with a 3.7 engine.
Here's what I've done so far.
I've recently repaired an engine that came with this used car I bought. Beforehand it was starting up but after the repair the car wouldn't fire. I repaired a bent valve and replaced the head.
I'd just like some idea of what could be wrong, any help or suggestions would be appreciated, thanks.
Kimiko is offline
post #2 of 4 Old 07-03-2012, 06:57 AM
streetglideok
2005 KJ Liberty
Need more information. You need fuel, air and spark for the engine to run. You've got air, but do you have compression? Do you have fuel pressure? Do the injectors work? Lastly, do you have spark? Get us some solid answers to those questions, then we can tell you where to go. Other then that, its going to be shotgun guessing.
streetglideok is offline
post #3 of 4 Old 07-03-2012, 09:01 AM Thread Starter
Kimiko
2003 KJ Liberty
I do have compression, fuel pressure, but the injectors aren't working but they were running before.
Kimiko is offline
post #4 of 4 Old 07-03-2012, 08:43 PM
streetglideok
2005 KJ Liberty
Which head did you replace, driverside, or passenger side? Passenger side has the cam sensor in it. If I remember right, earlier model 3.7L engines had a different config then the newer ones on the cam and crank toner rings for the sensors. Wrong one will cause issues, as the PCM cant identify cylinder 1
Engine Swap Starting/Timing Issue--3.7 02 Liberty with 03 3.7 Motor-Timing Dupe KJ Liberty Forum 7 10-21-2014 06:57 AM
02 liberty engine whining when starting in cold thecomposer KJ Liberty Forum 2 02-23-2011 04:25 PM
is the V6 engine an interference engine? 2005 liberty lostinvast KJ Liberty Forum 2 11-08-2010 07:41 PM
check engine light and engine runs rough. win93 KJ Liberty Forum 9 06-24-2010 06:05 AM
engine computer won't let my Liberty engine-brake downsdou KJ Liberty Forum 19 10-03-2006 10:39 PM
