Engine light after stuttering - JeepForum.com
post #1 of 18 Old 03-05-2012, 05:31 AM Thread Starter
ElectricFlow
Engine light started flashing after car made a rumbling/stuttering noise/feel. When accelerating past 50mph. After that it even idled poorly. I got my jeep fixed recently and was told my PVC hose was cracked however they did not replace it do to lack of part. Could this be causing the problem? Can I use a standard PVC hose and bend it to the right shape? Sorry for bad wording typing on phone.
ElectricFlow is offline
post #2 of 18 Old 03-05-2012, 08:51 AM
teamfast
2007 KJ Liberty
Can you run an OBD scan to see what code came up?
It may not be related to your PVC.
teamfast is offline
post #3 of 18 Old 03-05-2012, 09:17 AM
All3Sports
2004 KJ Liberty
Do you have to have a scanner for engine codes? I read you can just cycle the key from "off" to "accessory" 3 times it'll put it's own codes on the odometer.
02 KJ Renegade - Totaled....
04 KJ Limited - OME 927/948 General Grabber AT2 247/75/16
All3Sports is offline
post #4 of 18 Old 03-05-2012, 09:37 AM Thread Starter
ElectricFlow
I am at work now. I will check for codes when I make it home. Will post an update
Thanks
post #5 of 18 Old 03-05-2012, 02:03 PM Thread Starter
ElectricFlow
I have errors 300. 304. 305
post #6 of 18 Old 03-05-2012, 02:24 PM Thread Starter
ElectricFlow
The other work I had done to the jeep was replacing the valve cover gaskets. Could the Shop of done something during the repair?
post #7 of 18 Old 03-05-2012, 02:41 PM
All3Sports
2004 KJ Liberty
300 = misfire
304 = misfire cylinder 4
305 = misfire cylinder 5
Could have been mechanical/electrical failure but I don't have much experience with engine problems, I'd wait for some our KJ veterans to chime in.
post #8 of 18 Old 03-05-2012, 04:17 PM
teamfast
2007 KJ Liberty
Had any water on the engine recently? The spark plugs are in such a spot that if there is any moisture in there it cant escape. Youll have to remove the coils, dry them out and blow out any standing water from where the plugs are installed. Dont remove the plugs until you blow it out.
teamfast is offline
post #9 of 18 Old 03-05-2012, 04:26 PM Thread Starter
ElectricFlow
Up date
Found the problem, They removed the Coolant hose during the repair (the hose that runs above the engine back to the tank). It started leaking down onto the engine right on the spark plug areas (I am guessing 4 and 5). I stopped the leak for the most part. Taking it back in to get the leak stopped better and have them clean it up.
Question tho. on The coolant tank the nipple that the hose goes on, does it have the raise part all the way around it? or just half way around it. (Mine only has it half way, trying to see if its broken)
post #10 of 18 Old 03-05-2012, 04:27 PM
Backroads
Not to be the messenger of bad news but mine has been throwing a cel for cyl 4 misfire and its a blown headgasket. Hopefully yours in recent repair related.
Backroads is offline
post #11 of 18 Old 03-05-2012, 04:34 PM Thread Starter
ElectricFlow
Good call on the liquid
post #12 of 18 Old 03-05-2012, 04:35 PM Thread Starter
ElectricFlow
Ouch, whats the repair bill on that?
post #13 of 18 Old 03-05-2012, 05:44 PM
teamfast
2007 KJ Liberty
Thanks, I pressure wash my engines in the spring and one time the Liberty gave me misfires about two days after. It was this issue. Now I am sure to use a blow nozzle and get any standing water out of there.
teamfast is offline
post #14 of 18 Old 03-05-2012, 05:47 PM Thread Starter
ElectricFlow
Pressure washing the engine does not cause any other problems? Do you remove the battery prior to washing? just wondering
post #15 of 18 Old 03-05-2012, 05:50 PM
teamfast
2007 KJ Liberty
Nah, I have read that i should be covering elec connections and such but i generally give everything a hose down and not put any pressure on the CPU/ECU and actual connections. I hate working on a dirty engine. And if you dont do your own work your mechanic will appreciate it.
teamfast is offline
CRB 06 engine light on. rekab69 KJ Liberty Forum 2 07-07-2011 04:06 PM
check engine light and engine runs rough. win93 KJ Liberty Forum 9 06-24-2010 06:05 AM
cel light check engine? is this light supposed to come on for a second on Key on libertybratt KJ Liberty Forum 4 10-17-2009 09:46 PM
engine light ON EZLiberty KJ Liberty Forum 15 06-30-2009 08:21 AM
Engine light lit again?!?! psujeeperman02 KJ Liberty Forum 3 04-21-2006 08:33 AM
