#1 | |
electric cooling fan
why ? the auxillary electric cooling fan on 2006 kj crd my previous 2.5crd only had the viscos fan, when does this work? havent seen or heard it in nearly 2 years.
#2 |
my '05 crd has both electric and viscus/machanical fans. i read here years back that the machaical fan was part of the towwing package that i do have, and that without the tow package theres just an electric fan. do not remember if it applies to both gas and diesels. my electric fan is in front of the many heat exchangers on my crd (radiator, intercooler, a/c condenser, power steering and tansmission coolers) and i notice it running when the a/c is on.
#3 |
Correct - a Diesel engine produces only enuff btu to get the job done, unloaded or loaded - the viscous cabin heater is proof of that: note how in cool weather the unloaded engine rarely warms up, or warms up very slowly - different matter, however, when loaded, as in towing: yer Diesel makes ever so much more btu than a gasser (patooie!) version, and being turbocharged results in even more btu - unloaded, only time you'll ever see the towing package option electric fan running is when the AC is on - tack on a 5000lb trailer and it's a whole new scenario, as Exhaust Gas Temperature rises to meet the increased loading and Engine Coolant Temperature rises due to the increased btu output - if ya gotta drawbar on the back of yer KJ CRD, ya gotta auxiliary electric cooling fan
96 Dodge 3500 CTD, unseemly unstock If it's a Diesel thing, I do understand.... '05 CRD; INMOTION ST-II; EDGE Trail; Pricol Boost, EGT, Rail Press, Trans Temp; SEGR; Provent; Magnaflow; 2.5" Daystar f, OME r; Al's arms, Moogs; Ranchos; Rubicons, 2.55 Gy's; Suncoast T\C, Transgo '06 Cummins lift pump module, Fuel Manager\Filter, Filterminder Four in a row really makes it go |
#4 |
Hi
The UK get the fan as standard on the CRD it doesn't run when the air con is on and will only run when the temp is high so that is why you have never seen it start up. Regards, Merlin
UK Chrysler Jeep Master Tec. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
