Dual Emission MIL codes - 0420 and 0137 - JeepForum.com
post #1 of 3 Old 07-06-2013, 04:15 PM Thread Starter
mu2bdriver
2004 KJ Liberty
All,
My wife's 2003 Lib's MIL light has been intermittent over the last week. I hooked it up and stored are the P0420 and P0137 codes. The dealer gave her a laundry list of items that would 'require' replacement to clear the codes but I was wondering what the more likely culprit would be from a more knowledgeable group.
Thanks in advance.
ETA: Stock. 115k miles. Normal fuel consumption. Local daily driver. Smooth idle. No smoke at startup or while driving.
mu2bdriver is offline
post #2 of 3 Old 07-06-2013, 05:47 PM
streetglideok
2005 KJ Liberty
P0420, Bank 1 kitty cat is dirty and isn't working correctly or it thinks at least. Usually means B1 cat needs replacing, but I always verify before condemning. P0137, could be a symptom of a problem upstream with the engine running lean, or could be a faulty sensor. Hint, if you go to replace the O2 sensor, which I would consider before the Cat, do not, let me repeat DO NOT buy a bosch sensor. Use the OE, or an NTK(ngk) sensor.
streetglideok is offline
post #3 of 3 Old 07-08-2013, 10:44 AM Thread Starter
mu2bdriver
2004 KJ Liberty
Thanks!
