daughter's kj won't idle then does idle - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > daughter's kj won't idle then does idle
Unread 09-21-2013, 02:12 PM   #1
Skipper6413
2011 KK Liberty
Ok. Daughter has a 2002 3.7 liter kj that has 125000 miles. My first time seeing it it had the ac compressor go bad and radiator leak. Daughter had it towed and they had removed the compressor. It was shot anyway. I bypassed the compressor and changed the radiator this am. Now it will start and run but won't idle. After disconnecting and connect MAF sensor it now idles. ..thoughts? Maybe sensor going bad?
Skipper6413 is offline   Reply With Quote Quick reply to this message
Unread 09-21-2013, 02:14 PM   #2
Skipper6413
2011 KK Liberty
By the way when it runs it isn't rough running at all. Seemed smooth just won't idle then does idle just fine...weird.
Unread 09-21-2013, 02:14 PM   #3
tommudd
2004 KJ Liberty
Have you pulled any of the codes yet to see what comes up ?
04 Liberty, Kilimanjaro Edition, Rock Lizard RockRails/Roof Rack/Front-Rear bumper,32 inch Goodyear Duratracs,Moabs,4.10s/ 4.25 inch JBA Coilover lift /other goodies
tommudd is offline   Reply With Quote Quick reply to this message
Unread 09-21-2013, 04:37 PM   #4
Skipper6413
2011 KK Liberty
I don't have any fault codes.
Unread 09-22-2013, 01:32 PM   #5
Skipper6413
2011 KK Liberty
Well, evidently we fixed it. The tow service had disconnected the air intake off the manifold and the PCM had reset itself to run with "open air." When we connected the air tube back, the PCM was still compensating. By pulling the fuse/relay and inserting it, it caused the PCM to release thus fixing it. Anyway it's running very nice now.
