Cylinder Head Problems...How? - JeepForum.com
post #1 of 4 Old 03-17-2012, 05:22 PM Thread Starter
j123
Hello-
I am the original owner of a 2004 Liberty with the 3.1 engine. It has 80k miles on it. Oil changes always between 3-5k miles. Coolant was flushed around 50k and always kept full. Never taken off road, never over heated, mostly 30 min to 1 hr trips. Parked inside during winter.
Yesterday the engine light came on, cylinder 2 was misfiring. I changed the spark plugs, swaped ignition coils and the problem continued. Turns out there was antifreeze in the cylinder. I don't believe cracked heads and gaskets are common on this engine.
What could have caused this problem since I'm sure it never overheated?
What would you expect roughly parts and labor for a gasket replacement? What if one head needs replacement?
I'm concerned about having the problem arise again because I just don't understand how it happened in the first place
j123 is offline
post #2 of 4 Old 03-17-2012, 06:09 PM
dillonjm
2013 WK
Parts fail occasionally. It just happens through use at time with no fault on your part.
Hopefully its just the gasket, I'd get the head checked while you have it off.
If its just a gasket, you'll probably be out a few hundred bucks. The gaskets are cheap, but replacement is somewhat labor intensive compared to many jobs.
Expect significanty more for a new head.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #3 of 4 Old 03-17-2012, 09:24 PM
streetglideok
2005 KJ Liberty
What kind or color of coolant was put back in when it was flushed at 50k?
streetglideok is offline
post #4 of 4 Old 03-19-2012, 11:20 AM
Lafever25
Sounds like a blown head gasket or warped head, either way will cost a ton... A gasket costs about $30-60, oil and coolant about $50.... Hoses, belts, misc items that might need changing about $50... Labor for someone to do the job, like $1,000-$1,500... A new or remanufactured head about $300... But if coolant only ended up in the cylinder and not all over the ground may just be a blown gasket...
Lafever25 is offline
Coolant drips into cylinder head dlux KJ Liberty Forum 1 01-09-2012 05:30 PM
Master cylinder *help now* cheese4420 KJ Liberty Forum 2 05-02-2010 04:12 PM
Anybody have an 05 with 2.4L 4 cylinder metalhead KJ Liberty Forum 6 06-23-2009 05:47 PM
misfire in cylinder #3 2002jeepliberty KJ Liberty Forum 0 05-19-2009 07:16 PM
Transmission problems affect cylinder firing? jeep03kj KJ Liberty Forum 2 06-02-2005 01:01 PM
