CRD Winter Tips - JeepForum.com
post #1 of 7 Old 11-15-2013, 07:46 PM Thread Starter
BFonzik510
2005 KJ Liberty
CRD Winter Tips
This is the first winter with my '05 CRD, and I have already noticed longer crank times on a few mornings with temperatures down to about 20 degrees. Are there any common winterizing tips that I should consider? And what all should I know about its glow plugs and block heater?
Any information about this would be greatly appreciated, thanks!
BFonzik510 is offline
post #2 of 7 Old 11-15-2013, 07:55 PM
tommudd
2004 KJ Liberty
Check out LOSTJEEPS
whole section dedicated to CRDs
anything you ever wanted to know and then some is there
Including the NOOB Guide for new owners
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
post #3 of 7 Old 11-15-2013, 09:42 PM
oilbuner
2006 KJ Liberty
When the pavement ends, you better have some ground clearance!
oilbuner is offline
post #4 of 7 Old 11-16-2013, 07:50 AM
95BadBoy
Slightly slower crank time wouldn't be unusual. More than just a little slower crank time would maybe lead to following a couple of things below.
Load test your battery to make sure it is up to snuff. If it is not up to snuff look at a Sears Platinum group 34R instead of the Red Top factory battery. Cycle your glow plugs twice in real cold weather before hitting the key to start. If you have doubts that your glow plugs are working properly, have them checked. There is a upgraded version with a different voltage if needed. Use your block heater (on a timer), every CRD has one.
Good idea to run 8~10 oz or so of Power Service with every tank of fuel to lessen any chances of gelling issues in colder months. I also run 4 oz of synthetic 2 stroke oil (like Super Tech from small mart) in every tank - as ultra low sulfur diesel fuel has been around since 05 or 06. I'm sure by now you are already running winter grade fuel.
Hope this might be of some help.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #5 of 7 Old 11-16-2013, 08:34 PM
oilbuner
2006 KJ Liberty
I like that 2 stroke oil from Walmart. Super Tech in the blue plastic bottle. I use 8oz in a tank, but thats just me…If she's cranking slow 95BadBoy has it right with checking the battery. Simple but important
oilbuner is offline
post #6 of 7 Old 11-17-2013, 06:43 AM
95BadBoy
oilbuner
Yes, a bit of that marine Super Tech with each tank helps keep the little tractors happy happy happy. 4oz or 8oz, it is all good. Any thing to combat the effects of mandated ULSD pumped now days.
In my garage, I'm now down to only two pieces of 2 stroke yard equipment, a chain saw and a leaf blower. I ran out of the regular dino two stroke oil about two months back. Used the synthetic that I had been putting into the CRD. It was a dramatic improvement on the 30 year old leaf blower. No effect at first, but after about 10 minutes of use - it cleaned things out quite a bit. That old Stihl blower perked up and has been acting better than it ever has.
95BadBoy is offline
post #7 of 7 Old 11-17-2013, 06:01 PM
oilbuner
2006 KJ Liberty
For years I looked at that blue 1gal jug and new it was good for something, low and behold I found something I could use it on, My Jeephttp://blogs.dieselpowermag.com/6280...itive-is-best/
oilbuner is offline
