CRD Stripped Oil Drain Plug - Page 3 - JeepForum.com
post #31 of 40 Old 02-24-2010, 05:08 PM
CATCRD
2005 KJ Liberty
Originally Posted by WXman View Post
So I went to NAPA and they didn't have a da*n thing. Of course. I knew I was wasting my time going there. So I went to O'reilly and they had some gaskets but they were nylon, fabric, or copper. So I started looking around in the isle that had the PCV grommets...and I actually found a grommet that's thick rubber and slid snug over my 3/4" drain plug with a few threads exposed. I couldn't believe it. I think this will work perfect! I haven't tried it yet...but I think this is going to seal off much better and stop my leak.
Rubber will be degraded by oil and heat over time. Copper is your permanent solution.
CATCRD is offline
post #32 of 40 Old 02-24-2010, 07:28 PM
WXman
Copper doesn't "squish" enough. I've already tried nylon and fiber with no luck. Copper isn't going to do any better. I need something thick and "squishable" to seal off better around the plug.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #33 of 40 Old 03-13-2010, 05:31 PM
andrewvanh
2005 KJ Liberty
I bought one of these used and went to change oil today. The dealership had stripped the plug. It just spins in the pan and I can't get the thing out. I see the oil pan is ridiculously hard to take off. Does anyone have any suggestions. I am worried that I will get lots of aluminum shavings up into the pan and not get them cleaned out without pulling the pan.
andrewvanh is offline
post #34 of 40 Old 04-14-2010, 08:31 AM
WXman
Just an update....that PCV grommet I bought worked great! I had to cut it down just a tad...made a thick rubber "washer" out of it, screwed my Fumoto back in with the new rubber "washer" on and it worked! Doesn't drip any oil at all now!
I needed something "squishable" enough to take up the slack all the way around the plug as I threaded it in, due to the uneven thread tap job the previous owner had done, and this fit the bill perfectly!
WXman is offline
post #35 of 40 Old 04-14-2010, 10:22 AM
95BadBoy
Glad to here that solved the PITA problem the previous owner "left" for for you to find. I hate oil leaks in the garage and driveway bigtime.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #36 of 40 Old 04-15-2010, 03:14 PM
cowpie01
2006 KJ Liberty
Originally Posted by dabincharlotte View Post
Thanks, I am definitely leaning towards the Timesert.
The only thing I don't like about the Fumoto valve is its orientation straight down on the Liberty. All I can picture is something snagging it and tearing it out...
I have had a Fumoto valve in my CRD since I did the first oil change. I run my Libby thru cornfields, washed out draws, cow pastures and some mighty serious snow drifts out here on the farm where I live. Have never had any issue with the Fumoto getting "snagged" on anything. But then, I also have the skid plates and the Fumoto (without the nipple) does not protrude below the skid plate.
Environmentalist Green + Socialist Red = Facist Brown
cowpie01 is offline
post #37 of 40 Old 05-20-2011, 09:35 PM
Ozzyjeep
There seems to be Some confusion on this thread between the Petrol models and the CRD. Timesert do not produce a repait kit for the CRD.
Others mention an 18mm Helicoil. Could you please confirm that this is in fact the correct size for the CRD sump, and not the petrol sumps??
Ozzyjeep is offline
post #38 of 40 Old 05-20-2011, 11:16 PM
Reptile
1991 XJ Cherokee
Doesn't matter you have to drill in to put the insert anyway. Just get the size slighly bigger and use the matching plug.
Reptile is offline
post #39 of 40 Old 05-22-2011, 04:09 PM
Ozzyjeep
Thnaks reptile, I assume you are referring to the "timesert" ? I wrote to Timesert and they said they dont have a product suitable for the CRD..........
Ozzyjeep is offline
post #40 of 40 Old 05-22-2011, 11:14 PM
Reptile
1991 XJ Cherokee
Not sure, the stuff is usually called fix-a-thread, thread repair kit, etc. Brands like OEM makes them. They make different sizes.
You can also use a universal plug temporarily, or for the long run too... Works great.
Reptile is offline
2005 Liberty oil pan drain plug problem - found good replacement jlucas01 KJ Liberty Forum 0 01-18-2009 09:10 AM
stripped water pump bolt hole HELP!!!! RBPARROT KJ Liberty Forum 2 11-24-2008 01:25 AM
oil drain plug thread size for 08 liberty aquaholic_ KJ Liberty Forum 3 02-16-2008 07:35 AM
Liberty CRD Oil Drain plug wrench size dabincharlotte KJ Liberty Forum 16 08-01-2007 06:36 AM
Stripped transfer case fill plug rnbj KJ Liberty Forum 6 11-01-2006 07:53 AM
