Quantcast crd oil filter - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > crd oil filter
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 11-21-2009, 07:21 AM   #1
scottunangst
crd oil filter
has anyone(95badboy) used the higher capacity mobil 1 m1-301 oil filter yet on the crd. the reason i ask is because i got one for mine on a sugestion i got here but have not yet installed. a friend with a '95 GC with the 4.0 uses the m1-301 in it. i did not think the two motors could share the same oil filter.
scottunangst is offline   Reply With Quote
Old 11-21-2009, 07:53 AM   #2
95BadBoy
I'm useing the M1-301 on my 05 along with M1 5-40 TDT synth oil. Like it, fits well and gives the extra .5 qt capacity. Those two Jeeps just happen to have the ability to run that one. Have read a few times that there is less oil consumption by keeping the oil just below the full mark on our CRD's. Don't know if that is fact or fiction - But have been doing it on mine.
05 TJ RME 42RLE with some things
05 KJ CRD GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded
FS or FT (2) JK Rubi 17" Moab Rims - really nice shape
Need JK Rear Spare tire bracket for project
95BadBoy is offline   Reply With Quote
Old 11-21-2009, 08:05 AM   #3
scottunangst
thanks for the confirmation, i like to fill my oil filters before i install them, something the factory filter will not do. that would be a bad time to find out the m1-301 did not fit.
Old 11-21-2009, 01:18 PM   #4
95BadBoy
Your filter is actually way below the crankcase, because of which there is no need to prefill your filter on these. If in doubt - you could remove your filter before taking the plug out to test the idea. But I don't recommend it - it might make a large mess on the floor.
Many CRD'rs also use a Fumoto drain valve - do to the potential stripping of the alum oil pan - but that you probably already knew.
Old 11-22-2009, 05:51 AM   #5
scottunangst
if possible i like to fill oil filters as much as i can. my thinking is that the oil pump does not have to fill the filter first before the bearings get fed oil. you could test this by the time it takes after restart for the oil light to go out. it is only 2 or 3 seconds with the small/stock oil filter but that is run time with no oil pressure. i have the fumoto vave on now, we have discused the clearance it has with the nipple and room for the m1-301 filter earlier.
Old 11-22-2009, 07:10 AM   #6
95BadBoy
Partially filled is not a bad idea, though have not really noticed a long oil light - but probably have not been looking for that per say. I do understand the concept for a prefill though. Now that you mention it, I do remember the earlier discussion of the Fumoto and clearance. Must be just another senior moment.
I think this week, will start calling around to locate a better (read cheaper) source for these filters. It really seems the prices vary wildly - depending on the parts store/vender. Not to mention that there are fewer options up in this neck of the woods.
Old 11-22-2009, 07:55 AM   #7
scottunangst
best prices i have come across is autozone and advance auto will run 5qts. mobil 1 with m1 filter for $24.99 or $29.99. that is when i stock up. right now autozone has 5.28qt. jug mobil 1 for $26.99. download the form on their home page and mail in with receipt for $10 gift card.
Old 11-22-2009, 12:34 PM   #8
95BadBoy
Oil I can come by reasonably priced when Smallmart has thier M1 oil on sale. Filters here are on the high side at $13 + tax.
Old 11-22-2009, 12:38 PM   #9
CRD_Joe
2005 KJ Liberty
If you use synthetic oil (I use Amsoil European Car Formula) and an Amsoil Ea034 filter you really dont need more filtration. If anything add a bypass filter to your system.
2005 KJ CRD Sport
Suncoast, Transco, Inmotion, Provent, SEGR, CAT2, HID's, Samco hoses, louvers, V6 airbox, Fumoto, 2.5" cat back no muffler
CRD_Joe is offline   Reply With Quote
Glock Forum
