CRD long crank time - JeepForum.com
post #1 of 12 Old 11-05-2007, 08:20 AM Thread Starter
s68139c
CRD long crank time
Got an 06 CRD.... when after sitting overnight when abient air temp is below 10 degrees C, it will crank for around 11 seconds before starting, then run rough and smoke for a few seconds then clear up and run fine. Air/fuel filter is new, new glow plugs, injectors all tests ok, fuel pressure ok. But still cranks long time... Anyone run into this before?
s68139c is offline
post #2 of 12 Old 11-05-2007, 12:10 PM
indianrefining
Are you waiting for your glow plug light to go off?
indianrefining is offline
post #3 of 12 Old 11-05-2007, 02:49 PM
merlinTec
merlinTec's Avatar
HI
Check the fuel heater plug on the filter housing, unplug it and check to see if it’s burnt and also check for any signs of fuel in the socket. This is a new issue and the plug can’t take the amps the heater pulls and so over heats and melts. This lets fuel out and air in, you could find if you pump the prime pump fuel will come out of the plug. I did an 05 lib today with the same fault as you.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #4 of 12 Old 11-05-2007, 02:54 PM
chadhargis
2008 WK
I've always thought this was normal behavior for a diesel. They take a little while longer to start when it's really cold outside. They are compression ignition, which relys on heat created by the compression of the fuel/air mixture. If it's really cold, it will take a little while to get the combustion chamber warm enough to fire. Of course, when it does, you've got some raw, unburned fuel in your exhaust and it will smoke.
I wouldn't worry about it. If it's that big an issue, plug in the engine block heater.
Chad Hargis
Nashville, TN
2008 Grand Cherokee CRD
chadhargis is offline
post #5 of 12 Old 11-05-2007, 07:14 PM
CATCRD
2005 KJ Liberty
My 05 will crank in less than 2 seconds in any weather. Check what merlinTec said and also suggest to the dealer that your FCV may be sticking closed. It's like a throttle butterfly in your intake.
CATCRD is offline
post #6 of 12 Old 11-05-2007, 07:20 PM Thread Starter
s68139c
Originally Posted by merlinTec
HI
Regards,
Merlin
thanks for the input Merlin,We figured there was air getting in so we installed clear lines on the filter housing and let sit overnight, in morning there was large air bubles(2inches) in the clear lines. We eliminated the in tank module, no air coming from there, no cracks or holes in the lines, then we changed the filter housing. No codes in the system. Lots of power just doesn't want to start in the morning like she's hung over...
s68139c is offline
post #7 of 12 Old 11-07-2007, 08:57 AM
JoBo
Do a search over on LOST KJ. You have a classc air in the fuel and will need some type of lift pump. Air is seoerating from the fuel and getting trapped there. Elevated fuel pressures are causing the air to seperate from the fuel
JoBo
Columbus, Ohio USA
2006 KJ CRD Atlantic Blue Pearl Coat Limited
2000 Cherokee Classic with factory 16" wheels
JoBo is offline
post #8 of 12 Old 11-08-2007, 12:32 PM
merlinTec
merlinTec's Avatar
Hi
Here is some pictures so you can see what to look for
Regards,
Merlin
post #9 of 12 Old 08-22-2011, 04:24 PM
garrettb74
2006 KJ Liberty
I think I'm having the same probelm.
Originally Posted by merlinTec View Post
HI
Check the fuel heater plug on the filter housing, unplug it and check to see if itís burnt and also check for any signs of fuel in the socket. This is a new issue and the plug canít take the amps the heater pulls and so over heats and melts. This lets fuel out and air in, you could find if you pump the prime pump fuel will come out of the plug. I did an 05 lib today with the same fault as you.
Regards,
Merlin
I've had my CRD stall a couple times lately and won't start after unless I hand prime it. I did notice fuel leakage at this plug. What is the remedy?
garrettb74 is offline
post #10 of 12 Old 08-22-2011, 07:23 PM
95BadBoy
First post - welcome to JF -
Replace the fuel head & wire plug with the new revised replacement one. You should do this ASAP considering there is visible fuel leaking (not to mention the air ingress). You do not want to be a fireball on the roadway or have a three mile island type incident.
If there was no fuel leaking you could just leave the heater plug unplugged until you got to replacing it. Yours is not that way though. There have literally been a few CRDs melted to the dirt from this not being addressed. Just saying .....
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #11 of 12 Old 08-23-2011, 05:50 PM
GDE
2005 KJ Liberty
The link below has the part number for the redesigned fuel head assembly. This is a must have in your case and just good preventative maintenance for anyone else.
http://www.greendieselengineering.co...s/list/76.page
GDE is offline
post #12 of 12 Old 08-25-2011, 10:28 PM
CodyJ5
2005 KJ Liberty
If its cold outside, my '05 CRD takes a couple extra seconds to turn over. Like the guy said, normal for a diesel. I agree, plug in the engine block heater.
CodyJ5 is offline
Full Time/Part Time 4wd? Buffalo Chip KJ Liberty Forum 7 12-04-2013 07:11 PM
4wd part time and full time how to change noasad KJ Liberty Forum 27 06-05-2013 06:36 AM
2005 crc with" long time" power loss problem hammerboyone KJ Liberty Forum 1 10-28-2008 02:38 PM
How do I shift from part time to full time? BjBnet KJ Liberty Forum 6 04-10-2008 11:19 AM
Part time light on all the time sharhack KJ Liberty Forum 2 07-31-2007 09:58 AM
