CRD lift question - JeepForum.com
post #1 of 9 Old 05-08-2014, 11:20 AM Thread Starter
TheBrandyMan
2005 KJ Liberty
CRD lift question
Hey guys, i've been reading the forums for a while but just signed up today.
I have an 05 Liberty CRD and Im looking at getting a lift for it. I know the issue with the diesel only comes in the front because it is much heavier.
Ive read that with too much lift the CV axles will wear quickly but how much lift can you have before they start to wear?
Also, can you use rear coil springs and shocks from a different 05 Liberty lift kit and only get special front components? Thanks!
TheBrandyMan is offline
post #2 of 9 Old 05-08-2014, 12:50 PM
brendanc
2002 KJ Liberty
If you read around, most people will suggest just getting a whole kit or you will be redoing stuff you didnt have to.
Go here: http://jeepinbyal.com/jeep-liberty-k...ft-kit-kj.html
The 1.5" rating is for insurance reasons in Australia. The OME 1.5" kit is more like 2.25" or 2.5".
Mark the options you need. I would strongly suggest getting Al's A Arms as well. Medium strength springs will be fine unless you do a lot of towing.
If you get one of Al's lift kits (also on that site) then you can go up to 4" with the cut CVs. 6" requires a cradle drop, and honestly if you're going to do 6" you might as well do SFA... but be prepared to shell $$$$$ out for it.
02 Liberty, 4" JBA Gold Lift
brendanc is offline
post #3 of 9 Old 05-08-2014, 04:56 PM
95BadBoy
Get the OME lift for the CRD / or just do the Frankenlift. You will see 2.25 to 2.5" of lift approximately. Pound your pinch welds in the rear of the front wheel wells. You can't lift the CRD's as far as the gassers without running into some issues.
It does work quite well with these little tractors. Very sure footed, couldn't be happier. There is a DYI in the sticky's up top on a 05 CRD Frankinlift install...
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #4 of 9 Old 05-09-2014, 07:23 AM Thread Starter
TheBrandyMan
2005 KJ Liberty
Thanks! I had read about the frankenlifts and such I was just wondering because my friend has a lift from a gasser that I was wondering if i could salvage some parts from
post #5 of 9 Old 05-09-2014, 05:16 PM
95BadBoy
Maybe you could some pieces. The front on the CRD uses a stiffer coil in the front - over the gas one. The rears should be the same as in the gasser - but I don't have one of those, so one of the members here should chime in to confirm that or not.
95BadBoy is offline
post #6 of 9 Old 05-09-2014, 07:31 PM
tommudd
2004 KJ Liberty
Rear springs and shocks are the same gasser or CRD
You can use the 927s which we use on the gassers but I would go with the 790s in front, they are made for the CRD with aftermarket bumpers etc. Rated at 500 lb, not too still though as I have ran them on a gasser with an ARB etc
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
post #7 of 9 Old 05-11-2014, 09:18 PM
oilbuner
2006 KJ Liberty
Welcome to the forum. All the lifts talked about are good stuff. The CRD is a great Jeep to build. I went with JBA and still think its the best for IFS, however I have moved on to a SFA. The CRD with a 2.5-4" lift has more then enough power to turn any tire that will fit on an IFS suspension and still get good MPG's. If you have the $ to set your Jeep up, you will be happy by doing it. Don't forget about the brake line extensions if you get above 2.5". You can cut down your own CV axles and save$$$, or buy some Reel Good harden steel CV's already cut but they are Pricy. .
When the pavement ends, you better have some ground clearance!
oilbuner is offline
post #8 of 9 Old 05-13-2014, 12:49 PM Thread Starter
TheBrandyMan
2005 KJ Liberty
I ended up getting 3in lift, OME pre assembled front struts and RRO rear hydro shocks and springs. Thanks for the help!
post #9 of 9 Old 05-13-2014, 12:52 PM
tjkj2002
2002 KJ Liberty
Good luck,your going to need it with rro products.Have quality parts on hand when the rro stuff fails.
tjkj2002 is offline
crd , liberty , lift , question
