CRD Glow Plug Failure - JeepForum.com
post #1 of 9 Old 01-07-2008, 10:57 AM Thread Starter
andyc979
Hi everyone. Had an engine warning light on (again) so took the car to the dealer (again). They said a glow plug had failed and replaced it. The car is an 05 model 2.8CRD with only 19000 miles and this is now the 3rd time this has happened. I've now had glow plugs 1, 2 and 4 fail and am just waiting for no. 3 to go. Has anyone else had glow plug problems as I've run diesels for many years and never had failures like this on other vehicles?
PS Using the key on-off (x4) method I showed P1276 on the odometer. An internet site gave this as "accelerator pedal position sensor1 circuit performance" but the dealer said they picked up a completely different code using their plug-in tester which led them to replace the glow plug.
andyc979 is offline
post #2 of 9 Old 01-07-2008, 01:01 PM
merlinTec
merlinTec's Avatar
Hi
Glow plug failure was very common but they upgraded the glow plugs and a flash for the ECM to stop them burning out. Have they done the flash? There should be a label on the ECM under the bonnet (hood)
P0671-4 are glow plug fault codes P2120-5 are pedal fault codes Can’t find P1276.
I would say they are replacing the plugs with incorrect ones or they have not carried out the T.S.B 18-009-05 if you need to point it out to them.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #3 of 9 Old 01-07-2008, 02:06 PM Thread Starter
andyc979
Thanks Merlin. I'll check with my dealer here in Inverness (Bonnie, but chilly, Scotland) to see if they've done as you suggest.
andyc979 is offline
post #4 of 9 Old 06-04-2013, 03:00 PM
crs524
2008 WK
After 2 glow plug and a control module I figure it how.
First from the passanger side front to back is cylinder 1,3,5 but for the glow plug CCT it is 1,2,3
From the driver side (left hand in Canada) cylinder are 2,4,6 and for the glow plug it is 4,5,6
Here is the wiring diagram for the glow plug CCT
crs524 is offline
post #5 of 9 Old 06-05-2013, 01:42 AM
Billwill
2002 KJ Liberty
How do you get 6 glow plugs on a Jeep liberty CRD?
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #6 of 9 Old 06-05-2013, 01:48 AM
Billwill
2002 KJ Liberty
best place for CRD issues is the CRD section at:http://www.lostjeeps.com/forum
The replacement Glow Plugs from the dealers are 5 volt plugs and need a new plug controller to go with it and need to have the ECM programmed by the Dealer before connecting up the new glow plugs.
Most CRD owners are rather buying 7 volt metal glow plugs from an Italian company called Ecotec....these do not need a new glow plug controller or re-programming of the ECU and have a good reputation......check out Lost for details
Billwill is offline
post #7 of 9 Old 06-06-2013, 07:58 AM
dcxman
2006 KJ Liberty
I bought two from this company. Expect 13 days for delivery.
http://www.dieselglowplug.com/gx3123...lfjd30mfcla5c2
06 Jeep Liberty crd- 245/70/16 tires, fumoto valve
03 Neon
96 Ram 1500, 5.2,
99 Harley Sportster
88 Ford 350 diesel dump truck
02 Northwing Maverick Legend weight shift trike
dcxman is offline
post #8 of 9 Old 06-06-2013, 05:02 PM
95BadBoy
dcxman
That looks quite interesting. I see the discounts for larger orders.
Let us know what you think about em.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #9 of 9 Old 06-07-2013, 06:58 AM
dcxman
2006 KJ Liberty
Originally Posted by 95BadBoy View Post
dcxman
I only used one of the two plugs in order to replace a failed one on a good cylinder. I still have one to use in the future. The #1 cylinder plug has been bypassed due to leakage caused by ceramic tip going through head. Tried to fix it by milling head. Helped some but still leaking about a quart every 5k miles. Been that way for over 53k miles. May replace head at 200 k maintenance.
03 Neon
96 Ram 1500, 5.2,
99 Harley Sportster
dcxman is offline
CRD, Where is Glow Plug Relay Blindminer KJ Liberty Forum 1 12-12-2006 07:47 PM
CRD TSB: Torque Convertor, Glow Plug, Brake Switches Valkraider KJ Liberty Forum 4 03-18-2006 12:47 AM
Glow Plug Light? Drewd KJ Liberty Forum 11 02-13-2006 11:26 AM
How Long does your Glow Plug Light stay lit? FarmJeepCRD KJ Liberty Forum 3 09-19-2005 07:13 PM
"glow plug light" oneminddoc KJ Liberty Forum 4 08-21-2005 09:36 AM
