CRD Died!?!? - JeepForum.com
post #1 of 29 Old 09-09-2006, 10:51 PM Thread Starter
rmnoonan
CRD Died!?!?
Trusted advisors-
I was driving tonight, going about 55MPH when the CRD lost some power... it kept going but when I pushed on the gas, the engine/trans started to shudder (like when only one window is open) and started making a lot of noise. I'd push the gas, and it wouldn't give me any more power. It wasn't stopping or slowing down, per se, but it just maintained power and woudln't give me any more.
I pulled over to the side of the road and turned the engine off. When I tried to start it up again it wouldn't at all... it sounded like the engine was clogged up or something, just wouldn't crank at all.. So, I pulled out the warranty roadside assistance card, dialed up the 800 number, and just when someone answered the phone the CRD started right up and drove 30 miles without a hitch!
ANYONE HAVE ANY CLUE WHAT IT IS???
The only thing I did today that was different was I put it in 4-LO for a little <10MPH straight driving stint just to see it...could that have messed up my car?
Ryan
rmnoonan is offline
post #2 of 29 Old 09-10-2006, 06:38 AM
Cowpie1
Seems like most all of us have had the problem early in our CRD relationship.
I was out of state with my semi when my wife called me with the same problem. I told her that since the engine and tranny are all on computer, turn it off, wait about 15-20 seconds and restart. It started back up and has run good since. That was a few months ago.
Have never quite figured out the problem, but this has also been noted on the semi's with auto shift transmissions. Seems, for some reason, that the various computers get to not talking nice to each other. A reboot and they are fine.
Cowpie1 is offline
post #3 of 29 Old 09-10-2006, 06:52 AM
VTNomad
Diesel
You might have got a hold of some bad fuel. It's happened to me a time or two. I always try to buy my fuel along the interstate where a lot of truckers go.
2012 Black Jeep Wrangler Rubicon 2-door
VTNomad is offline
post #4 of 29 Old 09-10-2006, 07:49 AM
03blackfx4
Could be bad fuel, a clogged fuel filter or air in the fuel, all of which will cause exactly what you stated.
03blackfx4 is offline
post #5 of 29 Old 09-10-2006, 08:46 AM
homebudz
If it was "bad fuel",or a "clogged filter",the problem would not go away with just a restart,imho.
2008 JK Wrangler X with the "S" package.Flowmaster 40.K&N dropin.
homebudz is offline
post #6 of 29 Old 09-10-2006, 09:22 AM
JoBo
Your not alone. See this thread:
http://www.lostkjs.com/forum/phpBB2/...ic.php?t=11620
JoBo
Columbus, Ohio USA
2006 KJ CRD Atlantic Blue Pearl Coat Limited
2000 Cherokee Classic with factory 16" wheels
JoBo is offline
post #7 of 29 Old 09-10-2006, 10:21 AM
BVCRD
Sounds like you had a failure with one of the EGR components. Wouldn't say it happens to everyone as it hasn't happened to me yet. It went into the limp in mode. When you restart it, it sort of resets things and you're good to go until it happens again. Have it checked out because it WILL happen again.
2006 Jeep Liberty Sport CRD
BVCRD is offline
post #8 of 29 Old 09-10-2006, 10:39 AM
03blackfx4
If the fiter was semi clogged then it is possible as the "dirt" would settle to the bottom of the filter when the flow stopped then come back. I could also be the EGR valve as noted, this could cause boost to bypass back through the intake. Just wondering why don't you guys unplug your egrs like other diesel owners?
post #9 of 29 Old 09-10-2006, 04:14 PM
RFCRD
Unfortunately, it's not that simple on this engine. The computer controls on the EGR and other related systems make it tinker-proof. Even plating over an EGR tube port will throw a CEL.
RFCRD is offline
post #10 of 29 Old 09-10-2006, 04:18 PM
flman
2006 KJ Liberty
I tried this, and got the CEL. Will it reset itself or do I need to go to the dealer. Will an OBD reader reset this? Or does the CRD use a special OBD reader?
Still Burnin Oil since 1992!
GDE ECO Tuned 2006 CRD Sport Black, B&G Trans drain kit, Front and rear hooks, Full Skids
GDE HOT Tuned 2006 CRD LTD Silver, B&G Trans drain kit GDE TCM tune
2010 MB 2500 Sprinter Van
2005 MB 2500 Sprinter Van
flman is offline
post #11 of 29 Old 09-10-2006, 04:55 PM
flman
2006 KJ Liberty
Owners manual says a CEL will reset itself with out a trip to the dealer.
flman is offline
post #12 of 29 Old 09-11-2006, 06:09 AM
cerich
I don't think it was EGR related, sound like the TC was locking/unlocking confused enough to throw a code so the unit went into limp mode. The restart worked fine because the TC wasn't confused anymore.
You should make a NHTSB report, suddenly slowing down on a highway at night with no brake lights can be a receipe for a rear ender!
Check out the CRD section in lost, others are doing just this to try and force DC to find/fix the issue.
cerich is offline
post #13 of 29 Old 09-11-2006, 06:59 AM
BVCRD
The way he explained it is EXACTLY what happens when the EGR goes bad.
BVCRD is offline
post #14 of 29 Old 09-11-2006, 07:25 AM
cerich
I just reread his post and you are correct, I've been having the bucking like heck issues that go with the TC, so when I read shudder that's what I thought of.
The EGR is still a safety issue with how it behaves when bad.
cerich is offline
post #15 of 29 Old 09-11-2006, 07:31 AM
BVCRD
Basically, anything that happens in traffic can be a safety issue. Even a flat tire, but I dought they are going to demand that car manufacturers start putting run flats on every vehicle. The EGR failure at least let's the driver limp off to a safe place. Then shut it down, and restart to get home. Better than some breakdowns.
BVCRD is offline
Battery Died Lcars KJ Liberty Forum 13 08-14-2010 07:57 AM
06 Libby died!!!!! bikinman1226 KJ Liberty Forum 1 06-22-2009 11:10 AM
Help...My Jeep Has Died! nicherokee KJ Liberty Forum 5 07-17-2007 06:46 AM
My V6 has died!! numedium KJ Liberty Forum 13 03-26-2006 08:06 AM
CRD died macd KJ Liberty Forum 4 09-03-2005 09:23 AM
