Coolant smell - JeepForum.com
post #1 of 6 Old 04-22-2013, 11:24 PM Thread Starter
DarkSport11
2011 KK Liberty
Coolant smell
I can smell coolant through the vents every time I put my heater or defroster on. I can also smell it outside the car after driving and parking. I have checked the passenger side carpet to see if it's wet thinking maybe the heater core is the problem but it's dry. There is no coolant on the ground under it and no visible leaks from any hoses. The coolant level stays where it's supposed to, I'm stumped. Anybody have any ideas or have these symptoms?
DarkSport11 is offline
post #2 of 6 Old 04-23-2013, 07:58 AM
Bain98xj
You could still be loosing coolant thru the heater core. And it may or may not leak on the floor. A lot of times it will slowly leak out of the a/c drain and run down the firewall slowly. If your smelling it inside but dont see a leak I would say thats uour answer
Bain98xj is offline
post #3 of 6 Old 04-23-2013, 09:14 AM Thread Starter
DarkSport11
2011 KK Liberty
Thanks I'll check it, I was thinking the heater core also.
post #4 of 6 Old 04-24-2013, 07:18 AM
Chipppy
2002 KJ Liberty
I found a crack on the upper right hand corner of my radiator the other day. I was seeing coolant on my a-arms and on my skid and finally found where it is coming from. New radiator only runs like 175 going to have to swap in a new one.
Chipppy is offline
post #5 of 6 Old 04-24-2013, 07:43 PM Thread Starter
DarkSport11
2011 KK Liberty
I wish mine was that simple, I've already put a new radiator and A/C condenser about a year ago. I checked the radiator and it's good, hoses are good as well. If it does turns out that it's the heater core I'm looking at a big job ahead of me. I think it might be a pinhole in the heater core because the coolant level never moves. I was thinking about flushing out the system and putting a coolant system sealer in it when I refill it temporarily until I have the time to pull it apart. Has anyone had any success with cooling system sealers, not that thick goopy stop leak crap? Valvoline has Zerex Super Sealer that claims it seals without clogging your cooling system.
http://www.valvoline.com/products/co...-treatments/47
post #6 of 6 Old 04-25-2013, 08:27 AM
oldfamilyguy
I wouldn't use any of those leak sealers and risk clogging things up, especially since you have the new rad in there. If its not too terrible to live with a little longer you will be able to get by without heat soon, then just bypass the heater core and you'll have a few months stink free to get it done. If you do it that way though, it will be the quickest summer you ever had and before you know it snow will be coming and you still don't have it done. I've been through that more than once.
oldfamilyguy is offline
