Coolant fluid change only 6 quarts drain? - JeepForum.com
post #1 of 7 Old 10-23-2010, 10:05 AM Thread Starter
dean69
2002 KJ Liberty
2002 Liberty
Ok, as per the Jeep Service Manual, I start this procedure and only 6 quarts drain out. How to get the rest out and how do you refill. I have seen no true answers on this. Should the bleeder screw be used?
Thanks
dean69 is offline
post #2 of 7 Old 10-23-2010, 10:54 AM
ThunderFoot
You need to open the pet**** on the bottom of the radiator as well as opening the drain plug somewhere on the engine block in order to complete evacuate the system. OK, well, that's what we had to do on the older cars and trucks.
2007 JK Wrangler X Steel Blue Metalic Gray Cloth 3.8L V6 6MT
Freedom Top (Black) Soft Top (Black) 285/75R17 TOYO Open Country AT Pro-Comp 3036 17x9 Alloy Wheels TUFFY Security Drawer Delta Quad-Bar Xenon Headlights JK 6-Switch sPOD Source SuperChips Flashpaq Tune
Diode Dynamics LED License Plate Cobra 75 WX ST 4' Wilson Antenna AIRAID SynthaMax Cool Air Dam Intake System Hella FF 500 Driving Lights Hella Black Magic Driving Lights Smittybilt G.E.A.R. Tailgate Cover
9" Billet Antenna RR XHD Bumpers Fore & Aft with Storage Ends and Spare Tyre Carrier XRC8 Winch 2.5" Pro-Comp Suspension Bilstein Shocks RECON LED Smoked Turn Signals & Fender Lens
Colorado Jeep Club Member #1958
ThunderFoot is offline
post #3 of 7 Old 10-23-2010, 11:24 AM
dcxman
2006 KJ Liberty
Yep, and the pet****s were easier to find. Sooooooooooo, where is it?
06 Jeep Liberty crd- 245/70/16 tires, fumoto valve
03 Neon
96 Ram 1500, 5.2,
99 Harley Sportster
88 Ford 350 diesel dump truck
02 Northwing Maverick Legend weight shift trike
dcxman is offline
post #4 of 7 Old 10-23-2010, 11:25 AM
dcxman
2006 KJ Liberty
Ha ha ha. They censored pet drain.
03 Neon
96 Ram 1500, 5.2,
99 Harley Sportster
dcxman is offline
post #5 of 7 Old 10-23-2010, 02:57 PM Thread Starter
dean69
2002 KJ Liberty
great job Jeep
much corrosion after 90K,
dean69 is offline
post #6 of 7 Old 10-23-2010, 03:03 PM
95BadBoy
I guess pet rooster will need to used from now on.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #7 of 7 Old 10-23-2010, 08:13 PM
ThunderFoot
It will be low on the engine block. The position will differ with each type of engine.
Differential Fluid Change sevenn07 KJ Liberty Forum 26 08-21-2010 11:00 PM
change transmission fluid? tygirl KJ Liberty Forum 11 06-25-2010 09:13 AM
Transmission fluid change TEO_P KJ Liberty Forum 1 08-03-2009 09:11 AM
Rear Differential Fluid Change 02LibertyLmtd KJ Liberty Forum 4 02-04-2006 08:12 PM
How do I change my tranny fluid? LIYANG KJ Liberty Forum 8 01-11-2006 05:01 PM
