Condensor problems??? Please help!!! - JeepForum.com
post #1 of 4 Old 06-26-2012, 09:37 PM Thread Starter
dm4gators
My AC in my 2005 Jeep Liberty stopped working 3 weeks ago. Since then I added refrigerant and it seemed to work well. Today while I was at a red light, it stopped blowing cold (still blew hot) and when I stepped on the gas it got ice cold again. Is this the condensor? It only does this when the vehicle is not moving. If so, how hard is it to replace? Any advise on where online to get one from? Any tricks or must knows? TYVM!!!!
dm4gators is offline
post #2 of 4 Old 02-10-2015, 10:27 AM
dcowans
Check your fan
dcowans is offline
post #3 of 4 Old 04-09-2015, 02:08 PM
streetglideok
2005 KJ Liberty
Yep check the fan. Should be a two speed fan, and you likely lost the low speed. When you Rev it up, it may build enough pressure to force the high speed on. Do not, repeat do not waste your money on a Dorman unit.
streetglideok is offline
post #4 of 4 Old 05-27-2015, 06:07 PM
Sparky1234
I would recommend checking the high cap (idk if that's the official name of it). Basically, the cap all the way to the left in the engine compartment that you use when adding coolant.
Crank the car, turn the AC on full, then check to see if any coolant is leaking out of that area. There is a stem in it that can sometimes come loose or allow it to leak--this was the case with mine AFTER I had the air compressor replaced because it too did not work.
It's a quick fix if that's the problem, hopefully it's not your compressor. Good luck!
Sparky1234 is offline
Problems with App after going to iOS 5.0 Heath JeepForum Announcements 0 10-22-2011 12:34 AM
PM problems. ryan_289 JeepForum Announcements 7 08-11-2011 09:47 AM
Problems? Big-n-Broke-YJ JeepForum Announcements 3 12-23-2007 10:15 PM
DB Problems dakuda JeepForum Announcements 5 08-15-2006 08:35 PM
Having Problems with JF? Try This... dakuda JeepForum Announcements 1 12-22-2005 07:13 AM
