codes P0B08, P0003 P0000 - JeepForum.com
post #1 of 5 Old 06-23-2012, 06:46 AM Thread Starter
mikecw32
Hi
my jeep liberty 2.8lt crd has 3 codes/fault which i cant find what they are, P0B08, P0003 ,P0000 stored, the other 2 are active. Help would be much appricated
mikecw32 is offline
post #2 of 5 Old 06-23-2012, 08:02 AM
Billwill
2002 KJ Liberty
Originally Posted by mikecw32 View Post
Hi
I cannot find any of those codes in any of my FSMs or on any of the jeep forums.
How did you extract those codes?
What year is your CRD?
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #3 of 5 Old 07-06-2012, 06:33 AM Thread Starter
mikecw32
Local Garage put on a computer and got them, on clear they come back but engine seems to run ok.
I did find something hat suggsted it was a poor earth, is this likely?
mikecw32 is offline
post #4 of 5 Old 07-06-2012, 06:36 AM Thread Starter
mikecw32
Originally Posted by Powerslave View Post
P0B08 - Generic: Auxiliary Transmission Fluid Pump Motor Phase W Current High
P0003 - Fuel Volume Regulator Control Circuit Low.
P0000 - No Self Diagnostic Failure Indicated
Thanks, but what need fixing with regard to the Fuel Volume regulator and Aux Trans Pump, Earths? it only done 22K Miles
mikecw32 is offline
post #5 of 5 Old 07-06-2012, 06:45 AM
streetglideok
2005 KJ Liberty
Both codes could be set due to poor grounds, or earths in your neck of the woods. Find the wiring diagram, see if the components share a ground, and check it. I dont know the exact year of your jeep, but if its more then a couple years old, ground/earths can be a factor.
streetglideok is offline
how do you erase the obd II codes (check engine codes) MoD KJ Liberty Forum 3 06-24-2012 07:07 AM
codes richm20 KJ Liberty Forum 11 05-13-2011 03:56 PM
obd codes rfbrenn KJ Liberty Forum 2 08-10-2009 11:43 AM
CEL with 2 codes =/ brewcider KJ Liberty Forum 4 07-08-2009 05:30 PM
Can somebody tell me what these codes mean? Mike K. KJ Liberty Forum 5 09-30-2005 05:03 AM
