Code P0654 and P1276 - JeepForum.com
post #1 of 9 Old 05-24-2014, 08:45 AM Thread Starter
Clannad48
2004 KJ Liberty
Ok, so having followed the advice from the forum on obtaining the error codes for my 2005 Jeep (Cherokee in the UK) I have found the following codes come up
P0654 Engine RPM Output Circuit Malfunction
P1276 Accelerator Pedal Position Sensor 1 Circuit Performance
So as a total noob can someone please tell me what I am looking at - is this something to worry about - please bear in mind that as a mere female I will probably have to take this to a local garage if it needs sorting.
Many thanks
Clannad48 is offline
post #2 of 9 Old 05-25-2014, 01:50 PM Thread Starter
Clannad48
2004 KJ Liberty
Anyone
post #3 of 9 Old 05-25-2014, 08:56 PM
tjkj2002
2002 KJ Liberty
Yeah your going to have someone look at it unless you have the correct scan tool to access that data.
tjkj2002 is offline
post #4 of 9 Old 05-26-2014, 12:34 PM
95BadBoy
Originally Posted by Clannad48 View Post
Anyone
Not 100% but, did a quick Google from some over the pond postings.
As the CRD was not available in the US until "05", the info found - P1276 pointed to a glow plug issue. The P1684 was stated that the PCM memory has been cleared out or that no trouble code was present at the time of scan. Very little help, I know.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #5 of 9 Old 05-27-2014, 02:52 AM Thread Starter
Clannad48
2004 KJ Liberty
In the UK the car is badged as a Cherokee but it seems that if I want any info I have to look at the US Liberty
Thanks, I've also done some research, the P1276 seems to relate to a sensor on the transmission (automatic). As I had an issue with the transmission last year which required replacement and is still under warranty I shall see if this is covered by this warranty.
Unfortunately the other code is P0654 not P1684 and relates to the accelerator pedal sensor. I am hoping that this will also relate to the transmission replacement.
I love this car but it just seems one expensive thing after another goes wrong
post #6 of 9 Old 05-27-2014, 03:57 AM Thread Starter
Clannad48
2004 KJ Liberty
Thanks, I've also done some research, the P0654 (not P1684) seems to relate to a sensor on the transmission (automatic). As I had an issue with the transmission last year which required replacement and is still under warranty I shall see if this is covered by this warranty.
Unfortunately the other code P1276 relates to the accelerator pedal sensor. I am hoping that this will also relate to the transmission replacement.
Sorry I got the numbers the wrong way round, this is the correct information
post #7 of 9 Old 05-28-2014, 11:24 AM Thread Starter
Clannad48
2004 KJ Liberty
OK Peeps I took the car into the garage that did the replacement transmission last year.
They have checked it over and replaced the RPM sensor - the check engine light is no longer on and the car runs smoother.
Now the shock it came to a total of 36 - $60 for you in the USA and that included tax.
The stealership quoted a lot more than that for just checking the codes, without the part and labour.
I love a friendly no nonsense garage mechanic
post #8 of 9 Old 05-28-2014, 01:15 PM
oilbuner
2006 KJ Liberty
Good Job
When the pavement ends, you better have some ground clearance!
oilbuner is offline
post #9 of 9 Old 05-29-2014, 06:36 PM
95BadBoy
Glad to hear things are working and no more lights ! That was a decent price for the sensor installed.
95BadBoy is offline
