Code P0304 Cylinder 4 misfire...help - JeepForum.com
post #1 of 16 Old 08-10-2008, 02:27 PM Thread Starter
caliskier
2002 KJ Liberty
I got the code P0304 which I believe is a Cylinder 4 misfire. I just replaced my plugs with the same recommended plugs. Which cylinder is cylinder 4? What could cause this?
caliskier is offline
post #2 of 16 Old 08-10-2008, 02:52 PM Thread Starter
caliskier
2002 KJ Liberty
Actually, I found that the 4th cylinder is the middle left (passenger side). I guessed it was because the wire, or what ever that thing is called fit loosely over the plug. What could be the reason it won't spark?
post #3 of 16 Old 08-10-2008, 06:04 PM
merlinTec
merlinTec's Avatar
Hi
Cylinder 4 in is the plug next to the gearbox not the middle. The lead is most likely the fault.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #4 of 16 Old 08-10-2008, 06:21 PM Thread Starter
caliskier
2002 KJ Liberty
Originally Posted by merlinTec View Post
Hi
Regards,
Merlin
Sorry, which one is that if I am looking at it from the front of the jeep? 3.7 V-6, also "lead" is that the deal that the piece that fits over the spark-plug?
post #5 of 16 Old 08-11-2008, 05:53 AM
merlinTec
merlinTec's Avatar
LOL sorry thinking 2.4 so you have no leads just coils on the plugs so yes middle plug
post #6 of 16 Old 08-11-2008, 12:14 PM Thread Starter
caliskier
2002 KJ Liberty
Ok, so I have the right cylinder?
How do you diagnose the problem
post #7 of 16 Old 08-11-2008, 01:02 PM
merlinTec
merlinTec's Avatar
Hi
You have done the plugs so ruled them out. Should have done compressions and cylinder leak test when the plugs where out but now the next test would be to swap the coil over with another cylinder and see if the misfire moves to that cylinder, if so then that coil is more then likely your fault.
Regards,
Merlin
post #8 of 16 Old 08-11-2008, 08:35 PM Thread Starter
caliskier
2002 KJ Liberty
Hi
Regards,
Merlin
Moved the coil reset the codes and I do not get a code, drove it around the block, no code, but the engine still sounds like it is missing. I am wondering if the plug is bad on cylindar 4. Is there a way to test coil w/o driving the car?
post #9 of 16 Old 08-12-2008, 06:01 AM
merlinTec
merlinTec's Avatar
Hi
There is a misfire monitor test the dealer can do with DRB but other then that all you can do is use it as it can take some time to flag back up. You could disconnect the electrical plug on each injector one at a time to identify what cylinder is misfiring but this will flag up another code. You could also remove the plugs again and look for color difference on number 2 when compared to the others and then do compression test and cylinder leak test when you have the plugs out. Have you checked for air leaks?
Regards,
Merlin
post #10 of 16 Old 08-12-2008, 06:41 AM Thread Starter
caliskier
2002 KJ Liberty
Hi
Regards,
Merlin
Thanks again...
I think I might try that
Number 4?
I need a compressor for that right?, I don't have one.
No, how is that done.
I was not worried about compression issues as he engine was running fine, the reason for the plug replacement was because it was overdue and wanted to improve fuel effeciency.
It was very difficult to pull the socket off the plug with each instal due to the rubber piece inside. I wonder if I cracked the plug pulling it off, I think I might pull #4 tonight and look at it.
post #11 of 16 Old 08-12-2008, 10:37 AM
merlinTec
merlinTec's Avatar
If it's only has misfired after you changed the plugs then most likely faulty or damaged plug or incorrect cap. I was under the impression you did the plugs to fix the misfire.
post #12 of 16 Old 08-12-2008, 10:47 AM Thread Starter
caliskier
2002 KJ Liberty
Oops, should have been more clear. Ok, so cylindar 4 is the passenger side middle. I will pull the plug on it tonight and check, maybe some of the antiseze got on the plug and is gumming it up. I will try your other trick first though, I switched coil 4 w/ 1. Will start and pull the wire out of the coil on 1 to see if the engine sound changes. If it does then I know that it wasn't the coil and must be the sparkplug on 4. If it doesn't then it must be the coil and the spark plugs are all good. Have to run to the dealer anyway, I can drive over there on 5 cylindars and see if the code comes up.
Thanks for your help.
post #13 of 16 Old 08-12-2008, 12:12 PM
merlinTec
merlinTec's Avatar
Hi
Don't pull the wires off the coils when it's running, this is bad practice as you get unburnt fuel going down the exhaust to the cat. I said the plug on the injectors.
post #14 of 16 Old 08-12-2008, 04:33 PM Thread Starter
caliskier
2002 KJ Liberty
Hi
Oh, should have read that before I did it. Now I have error P 0351 which is a coil A malfunction. I was pluging in and unplugging the coil with the engine running, did it 3-4 times to hear the engine change. Wonder if I blew it.
post #15 of 16 Old 08-12-2008, 05:21 PM Thread Starter
caliskier
2002 KJ Liberty
MerlinTec. Thanks for your time, I appreciate it. I pretty much wasted it. The car is fixed now, running fine.
Before I say this, I do have a degree in Mathematics.
I found my problem, don't know if I should say this as I am going to get ridiculed royally…..
I didn't put the damn spark plug in the hole.
"Hi, I'm the dumba$$!"
Liberty Cylinder Misfire / Computer issue? Rach KJ Liberty Forum 37 03-20-2016 10:22 PM
Cylinder Misfire johnboy2814 KJ Liberty Forum 9 04-24-2010 11:14 AM
P0304 Lodator KJ Liberty Forum 9 12-14-2009 07:39 PM
Misfire on #3 please help? gman781 KJ Liberty Forum 18 06-14-2009 03:42 AM
misfire in cylinder #3 2002jeepliberty KJ Liberty Forum 0 05-19-2009 07:16 PM
