Originally Posted by mrdoug61
Have check engine light. Found code, P 0455, Thru. ignition switch sequence, Thanks everyone. Problem was EVAP system leak, gross. Found rubber tube on canister split. repaired.
Question: Will check engine light reset itself with this code? If not, is there a way to do it without going to dealer?
Thanks in advance
Doug
You can use this method,but will lose your presets on your radio:
To reset your engine codes:
Remove the negative terminal of your battery (10mm wrench).
Turn your ignition key to START and hold it there for about 15 seconds.
Turn your ignition key to OFF and remove it.
Connect the negative terminal of your battery.
Start but do not hit the throttle. Idle for about 10/15 seconds then turn off.
Restart the truck and drive as usual. It will take at least 12 starts and 48 miles to fully retune the computer. Hard Codes leave a shaddow for 40 full cold starts
