Check Engine Evap Sensor '03 3.7L - JeepForum.com
post #1 of 2 Old 01-04-2010, 06:36 PM Thread Starter
Redrum257
Can someone give me a good checklist to go through when clearing up this code. I had it checked at autozone and of course forgot the exact code. Its definitely the evap emissions causing the light to come on. Not the cap as I made sure it was securely on by rotating several clicks. I noticed that the check engine light goes out if I fill the tank. Only when the level gets below half that the light comes back on.
Redrum257 is offline
post #2 of 2 Old 01-04-2010, 06:41 PM
tjkj2002
2002 KJ Liberty
The best way(and most times the only way) to properly diag a EVAP system is by having a smoke test done at a shop.
tjkj2002 is offline
CEL - evap sensor - repeatedly - common issue? LibertynJustice KJ Liberty Forum 9 05-01-2013 05:21 AM
How do I check if the engine is seized? mercfocus KJ Liberty Forum 6 02-13-2009 07:54 AM
Check Engine Light STACYMOLLOY KJ Liberty Forum 5 12-11-2006 03:47 PM
Check Engine and New here.. Jeff Bade KJ Liberty Forum 1 02-15-2006 01:42 PM
Check Engine Codes... Mitchb KJ Liberty Forum 13 12-03-2005 03:16 PM
