Check Engine Codes... - JeepForum.com
post #1 of 14 Old 11-25-2005, 11:06 AM Thread Starter
Mitchb
Ok is there a way to read the check engine codes without taking it to a service place, or having a computer to read them. In the past a lot of my cars have been read by simply placing a jumper wire in the plug in and it would blink the codes. Can that be done with the liberty? This is the second time my check engine light has come on since i bought the car a month ago and im starting to get pissed.
Mitchb is offline
post #2 of 14 Old 11-25-2005, 02:49 PM
FiEND
For the 1999 Jeep Grand Cherokee and up, you do the switching the key on and off 3 times, but not quickly. You turn it to on so the odometer turns on, turn it off, and then back on, wait for the light to turn on, etc. On the fourth time you'll get a code, or you'll get the word "done."
http://www.allpar.com/fix/codes.html
FiEND is offline
post #3 of 14 Old 11-30-2005, 07:16 PM
danoid
2005 KJ Liberty
Actually this works for nearly all Chrysler, Jeep, Dodge vehicles.
2005 CRD Limited Flame Red w/ Renegade rock rails & light bar, AirLift rear helper springs -225/75R16 MT/R's on cheap black steel wheels, dual MOPAR subwoofers & seat covers.
danoid is offline
post #4 of 14 Old 11-30-2005, 08:34 PM
learstroker
This does not work for the CRD. You will get a bogus code.
learstroker is offline
post #5 of 14 Old 11-30-2005, 10:32 PM
Bagger
It works on my CRD
Bagger is offline
post #6 of 14 Old 11-30-2005, 11:35 PM
marlon_jbt
2010 KK Liberty
For every couple people who say it works, there's always that one person who says "It doesn't work for this or that, or for a specific model year."
They're just not doing it right...
Red Jeep Club member # 264
marlon_jbt is offline
post #7 of 14 Old 12-01-2005, 02:57 AM
learstroker
I was able to get a code doing the key thing. However it was erroneous. Further discussion with both the Fairbanks and Anchorage Alaska Jeep Dealers proved that this method does not work for the 2005 CRD. They both said do not use the key method. I live in a remote area. I had to have a special scanner flown in to get the real code and fix the problem. The key method showed P0096, the scanner showed P0105. The correct part was ordered and the MIL fixed.
post #8 of 14 Old 12-01-2005, 02:59 PM
Torque Monster
learstroker,
By any chance, did you have a bad boost pressure sensor?
It measures both the intake manifold pressure and intake air temperature.
P0096 (Intake Air Temperature Sensor 2 Circuit Range/Performance)
P0105 (Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction)
Chris
- 36Kmi - SOLD
Ext. Black Clear Coat, Int. Dark Khaki/Light Graystone, 22G, Trac-Loc.
Torque Monster is offline
post #9 of 14 Old 12-01-2005, 08:32 PM
BradTE20
where does the code show up? the odometer display or the overhead display?
BradTE20 is offline
post #10 of 14 Old 12-02-2005, 12:33 PM
Torque Monster
The odometer.
Chris
- 36Kmi - SOLD
post #11 of 14 Old 12-02-2005, 01:57 PM
meh_kick
meh_kick's Avatar
I also couldn't get this method to work on my '04 Renegade... for what it's worth. BTW I think I "was doing it right."
If you can't beat 'em, join 'em.
meh_kick is offline
post #12 of 14 Old 12-02-2005, 03:31 PM Thread Starter
Mitchb
Well it seems that most of the people that say it doesn't work have the CRD. I just have a regular liberty sport. Could it possibly be different for the CRD?
Mitchb is offline
post #13 of 14 Old 12-02-2005, 07:22 PM
learstroker
Chris
I cannot get the exact part data until monday. It was however something about "intake pressure sensor" I think. Two technicians at differnt dealeships said that the P0096 code was not even valid for the CRD.
post #14 of 14 Old 12-03-2005, 03:16 PM
CRD
I'm doing it every time I try with 4 turns of the key. The fourth time being the one I stop on in the on position to look for the code. It does not work for me when I park the car after driving. It does not work for me when I try to do it two times in a row. It seems like I have to shut off the engine, leave the car, lock the doors and then wait a awhile for something to reset. After a little while when I come back, I can do the key trick and read the codes again.
CRD is offline
More engine codes EZLiberty KJ Liberty Forum 4 08-09-2009 12:09 PM
Check engine codes???? sefroe KJ Liberty Forum 22 03-22-2009 06:48 PM
Engine misfire codes intermittent now steady mdm001 KJ Liberty Forum 1 09-13-2008 01:31 PM
check engine light - codes vmckenny KJ Liberty Forum 0 04-03-2008 01:35 PM
Clearing Engine Codes... maascow KJ Liberty Forum 4 06-06-2006 07:53 PM
