Changing the timing chain - JeepForum.com
post #1 of 22 Old 03-11-2013, 03:38 AM Thread Starter
JeepNoob74
2004 KJ Liberty
Hello people! It is time for my 2004 Liberty to get the timing chain changed...
So I was wondering if you guys could recommend a particular timing chain kit brand?
I was looking it up in ebay and I found kits starting at 80$ !!
Then I found some other kits at $350
I was a bit confused as it seems kind of obvious there are differnet qualities out there, can you recommend an specific brand? Do they sell kits at the stealer... I mean dealer?
I dont really want to do this at the dealer as it will probably be about 700 dlls if I am lucky.
Are the 80 dollar kits so bad they wont hold for 60K-100K miles?
Is it recommended to change the water pump and oil pump at the same time ? Oddly enough I have seen some kits including the oil pump, some others both the water pump and oil pump and some others without any pump at all. On my smaller cars I usually change the water pump when changing the timing belt, but I am a Jeep noob!!
Also, since I guess I will have to purge the system of coolant, whats the recommended coolant for the Jeep Liberty??
Thanksss!!
JeepNoob74 is offline
post #2 of 22 Old 03-11-2013, 07:54 PM
TwoBobsKJ
TwoBobsKJ's Avatar
2003 KJ Liberty
Well, assuming you have the 3.7L, you don't need to change the timing chain. It's a lifetime chain system.
There are actually three chains: The primary chain from the crank to the idler gear; and then one to each of the cams. I wouldn't want to try that job with the engine in the Jeep - it was enough of a challenge with the engine out when I did an engine swap recently.
Unless you have severe issues with the timing chains - don't do it.
As for the coolant...Use HOAT only. I buy mine at NAPA - Zerex G-05. Don't bother with the universal types - they don't cut it. Two gallons of coolant and two gallons of distilled water and you're good (system takes 14 quarts.)
If you change the thermostat remember: The thermostat cone goes INTO the block, not into the hose.
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
post #3 of 22 Old 03-13-2013, 09:37 PM
oldfamilyguy
Like he says, 3.7 timing chains have no replacement schedule. They should last the life of the engine. Even some rebuilds don't need them. Probably that set you see for $350. 4 cyl. gas or deisel, different story. Timing belts and follow the schedule. If in doubt change it, if it breaks you have a big problem. $80 seems to be in the ballpark but I don't know for sure, never had or worked on either.
oldfamilyguy is offline
post #4 of 22 Old 03-16-2013, 09:38 AM
oldfamilyguy
de nada
post #5 of 22 Old 03-16-2013, 03:24 PM
Skipper6413
2011 KK Liberty
Good to know! Wife's KJ recently purchased with 75k and I was concerned about that!
Skipper6413 is offline
post #6 of 22 Old 03-16-2013, 03:50 PM
oldfamilyguy
The greatest concern with the 3.7 is overheating will kill it. So along with the usual maintenance be certain that the cooling system is 100%.
post #7 of 22 Old 03-16-2013, 04:53 PM
Skipper6413
2011 KK Liberty
Roger! That service will be next on the checklist! A LOT easier than timing chains!
post #8 of 22 Old 03-22-2013, 09:39 PM
streetglideok
2005 KJ Liberty
Thanksss!!
As has been said, there is no set schedule for timing chain replacement. Now if you have the 2.4L 4banger, that is belt driven, not chain driven. There are 3 chains on the V6 engine. If there is alot of racket coming from the chains, typically due to neglect of the engine, then you would need to change all 3 chains, the chain guides, and the hydraulic tensioners, plus gaskets. You would need to know how to line up the timing components exactly, or you will have some serious issues on your hands. I've all but given up buying junk on fleabay personally. $80 for a timing kit, you aren't getting much in parts, or quality. It's one thing to go cheap on something you can reach easily, but its another when you are dealing with major engine work, and the potential for major engine damage should an inferior part fails. Those kind of parts, Im usually going to source them from the dealer. I don't have much faith in parts stores junk either.
As for coolant, you need an HOAT coolant. It can come in the pinkish color like chrysler's, or gold color like ford. It is NOT the same as dexcool, or conventional green. There is no such thing as a coolant that works in all of them and performs to the design specs of the coolant meant for the engine. There are claims of it, but doesn't mean it works. Its out there to drum up business from shops that are too cheap to do it right.
streetglideok is offline
post #9 of 22 Old 03-23-2013, 10:07 AM
oldfamilyguy
I don't think the op really cares. He disappeared after his original and only post.
post #10 of 22 Old 03-03-2015, 09:45 AM
Bigdog1956
2005 KK Liberty
So I have a 05 Jeep Liberty and the motor is seized. Everything I read says the timing chain is life and shouldn't need to be replaced, so what would cause the motor to seize?
Bigdog1956 is offline
post #11 of 22 Old 03-03-2015, 06:56 PM
streetglideok
2005 KJ Liberty
No oil? Thrown rod? Timing chain runs the camshafts, and by itself would not really be relevant to an engine locking up. How low on oil was it? How often was it ran low on oil? How often was the oil changed? Is there any oil coming out of the sides of the engine?
post #12 of 22 Old 03-09-2015, 09:05 PM
olliehopnoodle
1982 FSJ Cherokee
Is it seized in both directions of movement? With the spark plugs out you cannot turn the engine by hand (socket on the crank pulley) in either direction?
These engines like to drop intake valve seats and hold the valve open which connects with the piston. But that will only keep it from turning in the normal direction.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #13 of 22 Old 05-18-2015, 02:38 PM
rcooper2382
I have a 2004 Jeep liberty we just changed all the gaskets on but now the timing chain sounds like it is slapping what should i do?
rcooper2382 is offline
post #14 of 22 Old 05-18-2015, 07:55 PM
streetglideok
2005 KJ Liberty
Really best if you start your own thread on this, honestly. What gaskets did you replace, and what all did you remove and install?
post #15 of 22 Old 06-07-2015, 07:39 PM
MustangShelly
2003 KJ Liberty
Thanks to all for this info! 2 yrs later, I googled similar question as original post person... you all saved me a LOT of hassle/worry/$.
MustangShelly is offline
