Changing oil pan gasket - is it a 1-man parking-lot job? - JeepForum.com
post #1 of 6 Old 11-16-2013, 12:36 PM Thread Starter
AVR2
I've got moderate wrenching experience - I've got as far as head gasket replacement on a 4.0L and lower control arms and ball joints on my KJ - so how feasible is it to attempt replacing the oil pan gasket on my KJ, working by myself in the parking lot of my apartment building? Is it enough of a PITA that I will just end up wishing I'd paid for a shop to do it up on their hoist?
AVR2 is online now
post #2 of 6 Old 11-16-2013, 07:06 PM
tjkj2002
2002 KJ Liberty
You either have to pull the engine or drop the cradle(and whole front suspension),and support the engine from above,to gain enough room to replace the pan gasket on a KJ with a 3.7.
tjkj2002 is offline
post #3 of 6 Old 11-16-2013, 08:12 PM
TwoBobsKJ
TwoBobsKJ's Avatar
2006 XK Commander
Here's a pic to show what tjkj2002 is talking about. This is from my engine swap back in February (put an '07 from a Dodge Dakota in my '03 Libby. A cam sprocket, crank reluctor ring and EGR blocking plate were needed to make it work):
The oil pan gasket doubles as the windage tray - and the tray is under the oil pickup tube which is bolted to one of the main bearing caps. And the oil pickup itself is bolted to the oil pump as you can see on the right edge of the block.
Without lifting the engine out the gasket will just have to keep dripping I guess...
Bob
SOLD: Highly modded 2003 KJ Liberty Renegade, Black
- Current Jeep 2006 Jeep Commander Hemi Limited - OME HD Springs/Bilstein 4600 shocks, AiRaid CAI, Billet Technology catch can, SuperChips tuner, RHR Nav upgrade, 1.5" wheel spacers
TwoBobsKJ is online now
post #4 of 6 Old 11-16-2013, 11:53 PM Thread Starter
AVR2
I'd forgotten about the need to support the engine from above... definitely easier and cheaper just to keep checking the oil level and dumping some more in as necessary It's not puddling under the engine, but the pan is constantly soaked in oil. Although I'm kind of OCD about oil leaks, the work involved in this is just too much right now.
AVR2 is online now
post #5 of 6 Old 11-17-2013, 05:40 AM
John317
Here is a band aid fix that I saw a mechanic do to help the person get by till they could get it fixed. He cleaned the oil pan and the area where it attached as best he could and applied sealant. It might help for awhile.
John317 is offline
post #6 of 6 Old 11-17-2013, 02:11 PM
donnie2002
John is right
donnie2002 is offline
