Changing front struts/shocks on 04 liberty??? - JeepForum.com
post #1 of 14 Old 01-11-2010, 04:45 PM Thread Starter
BeerMonkeY
ive never worked on a liberty before or really even looked under one so excuse my stupid question but do they have shocks or struts on the front and are they hard to change. id like to think im very mechanicly inclined as far as the work goes but wondering if i need anything speacial besides a spring comperssor if its a strut.thanks for the help
'92 YJ
'98 ZJ 5.9
'13 WK2 HEMI
BeerMonkeY is offline
post #2 of 14 Old 01-11-2010, 05:14 PM
95BadBoy
They have struts. IMHO it's quicker to have a local parts store thats capable (and has the equipment) to do the disassembly and reassembly of them for you. They are a bit more entailed than the JK's and TJ's. As I am finding out at this moment in time. I'm doing complete replacement (struts & springs) - so it is straight forward. Just do an alignment when complete.
If you do it yourself, and doing strut only - just use caution and good equipment to do the job.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #3 of 14 Old 01-11-2010, 05:56 PM
tjkj2002
2002 KJ Liberty
The fronts get classified as "struts" when in fact it is a coilover assembly with a shock.Struts take the place of a upper control arm and pivot and the KJ has a upper control arm and it does not pivot.So they are shocks(coilover setup).
As far as changing them it's easy,you will need coil compressors though and using 2 ratchet straps to pull the clevis back into place to put the lower bolt in makes the job real easy.
tjkj2002 is offline
post #4 of 14 Old 01-11-2010, 06:11 PM Thread Starter
BeerMonkeY
thanks for the info, ill prob tackle them myself and rent a spring compressor.
'92 YJ
'98 ZJ 5.9
'13 WK2 HEMI
post #5 of 14 Old 01-11-2010, 06:27 PM
tjkj2002
2002 KJ Liberty
As far as the spring compressors unless you have one of those professional wall mounted one about the only ones that work seem to work on the KJ coils is these in the link below(found at advance auto,similar at CarQuest and Napa) and about $40.
New Ampro Website
tjkj2002 is offline
post #6 of 14 Old 01-14-2010, 05:17 PM Thread Starter
BeerMonkeY
cool thanks for th link, ill make sure the one i rent looks like that one
'92 YJ
'98 ZJ 5.9
'13 WK2 HEMI
post #7 of 14 Old 03-21-2011, 11:16 AM
richm20
2006 KJ Liberty
I know im a bit late to the party but...http://www.harborfreight.com/automot...-set-3980.html
richm20 is offline
post #8 of 14 Old 03-21-2011, 01:10 PM
95BadBoy
Have been a fan of the compressors that have the extra locking security pins - that lock under springs as well as the standard curved tops on most of them. If the compressor shifts sideways on the spring - it is just a little bit more protection to keep a spring with a lot of energy in it from hurting or killing someone.
All though nothing beats common sense.
95BadBoy is offline
post #9 of 14 Old 03-22-2011, 01:16 PM
tommudd
2004 KJ Liberty
Don't value your life much do ya?
Either that or you haven't tried those on any aftermarket springs
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
post #10 of 14 Old 03-23-2011, 09:28 AM
Cards81fan
Cards81fan's Avatar
2005 KJ Liberty
My compressor look more like this:
They are a pain to get on and off the spring, but they are very secure. I trust them. They aren't harbor freight, but were auto zone or something like that. More than $15, I think 30-40-ish.
Mindset, skillset, toolset - in that order!
Cards81fan is offline
post #11 of 14 Old 03-23-2011, 09:37 AM
tommudd
2004 KJ Liberty
Good luck, they'll work on stock 310 lb springs fine, OME 400-500 not so good. faster and much easier to take them to a shop and have them compress them in my book.
MUDD'S MOTORSPORTS
tommudd is offline
post #12 of 14 Old 03-23-2011, 04:14 PM
bigjimslade
2007 KJ Liberty
Well that throws a wrench in my plans to do it on a Sunday. Unless I can talk a friend of my sisters into doing it at his shop on a Sunday. Might have to schedule a day off of work to do it. Are you recommending taking the old stuff into the shop with the new springs/shocks and have them assemble them?
07 KJ with OME springs, Bilstein shocks, some extra's for a total of about 3.5" of lift, JBA 4.5 UCA's, riding on 245/75-16 Duratracs mounted on black Moabs.
bigjimslade is offline
post #13 of 14 Old 03-23-2011, 06:26 PM
tommudd
2004 KJ Liberty
The main problem with all of the screw type compressors is they are hard to get in between the coils, not as hard to get them on the old springs of course but once you compress the OMEs it makes it real hard to get them apart/out. Can be done but huge PITA and got to be really careful. For someone not used to doing them I rate it a 9 out of 10 on the pucker factor
For me easier to drop them at a shop, have them compress them and be done.I can have the rear done while they compress the fronts. Even the high tech hydraulic compressor they have at the shop I use, my 500 lb OME790 jumped out and made a nice hole in the block wall.
MUDD'S MOTORSPORTS
tommudd is offline
post #14 of 14 Old 03-23-2011, 07:58 PM
Cards81fan
Cards81fan's Avatar
2005 KJ Liberty
To echo tomm's comments, it is doable but tricky. I actually used air tools (a ratchet, not an impact) to compress and decompress the springs. And it was a PITA to slip the tool out of the spring when done. The pucker factor is similar to working with garage door springs. If you know what your doing, and do it safely, it is not a problem. But you still worry.
I will say that the bigger problem was removing the "strut" plate studs and reinstalling them a new plate. I have a very small manual press, but it did not budge anything. I paid Pep Boys $30 and 20 minutes or so later I had my parts.
2004 Liberty Front Struts -- Write-up tcarlisle KJ Liberty Forum 5 02-01-2013 02:58 PM
Skyjacker Struts/Shocks on Stock Liberty jeep03kj KJ Liberty Forum 1 01-17-2006 06:55 PM
Has Anyone on Here changed the Front Struts to Shocks? 93_zj KJ Liberty Forum 1 11-14-2004 06:03 AM
rear shocks and front struts Tibia31 KJ Liberty Forum 0 05-13-2002 01:44 PM
Struts For the Liberty KJLiberty2002 KJ Liberty Forum 1 03-19-2002 08:37 AM
