Ceramic Brake Pads - JeepForum.com
post #1 of 9 Old 04-07-2012, 03:05 PM Thread Starter
jp7794
2006 KJ Liberty
Ceramic Brake Pads
Are ceramic brake pads for the front brakes of a KJ worth the extra money ?
Thoughts and opinions.
jp7794 is offline
post #2 of 9 Old 04-07-2012, 04:13 PM
mdougall
2004 KJ Liberty
Less brake dust.
mdougall is offline
post #3 of 9 Old 04-07-2012, 06:43 PM
tjkj2002
2002 KJ Liberty
I know my '02 KJ came from the factory with ceramic pads.
tjkj2002 is offline
post #4 of 9 Old 04-07-2012, 08:03 PM Thread Starter
jp7794
2006 KJ Liberty
That is interesting since it was 10 years ago when ceramic pads were pretty exclusive.
jp7794 is offline
post #5 of 9 Old 04-07-2012, 10:14 PM
tjkj2002
2002 KJ Liberty
Not really.10 years ago you could most likely count the number of vehicles that did not come with ceramic pads on both hands.
tjkj2002 is offline
post #6 of 9 Old 04-08-2012, 12:28 PM
Lafever25
Answer to your question is yes... Depending on you and your budget I guess. Ceramic pads create less dust and noise. Also they're not as stressful on your rotors so your rotors actually last longer or are in better shape so you won't need to re-surface them during next pad change.
Lafever25 is offline
post #7 of 9 Old 04-08-2012, 12:34 PM
tjkj2002
2002 KJ Liberty
Ceramic pads............
-less brake dust
-in some cases are very noisy and normal
-works better hot,not so good cold
-tears up rotors faster
-not good for very heavy vehicles or towing
Semi-Metallic...........
-little more brake dust
-works very well cold and hot
-softer so wears faster
-best for heavy vehicles and towing
-does not tear up rotors like ceramic pads
Organic.............
-cheapest of all 3
-extreme brake dust
-very soft so wears extremely fast
-does not work well cold or hot
-standard pad line at advance auto,autozone
-lower quality so often very noisy
tjkj2002 is offline
post #8 of 9 Old 04-08-2012, 02:26 PM
Lafever25
http://www.brakeworld.com/ceramic-brake-pads.asp
Could be read as a little bias, but so are opinions... I use ceramic because they last at least 50k, and I normally have rims so I don't want them dirty.. I also use drilled slotted rotors so it could be my rotors that just last forever.
post #9 of 9 Old 04-10-2012, 09:26 AM Thread Starter
jp7794
2006 KJ Liberty
Thanks for the input everyone. I drive a very short distance to work so I think I will stay with semi-metallic.
jp7794 is offline
brake rotors and pads jeepkj617 KJ Liberty Forum 10 09-21-2011 08:57 PM
brake pads: what would you put ? xxxracing KJ Liberty Forum 4 08-04-2010 04:38 AM
Changing Brake Pads 06 CRJ Ltd goudey KJ Liberty Forum 6 01-18-2009 01:02 PM
Aftermarket brake pads? LibertyHopeful KJ Liberty Forum 11 12-22-2008 06:10 PM
What brake pads do you use? Dupe KJ Liberty Forum 3 04-08-2005 02:40 PM
