Car Stereo - JeepForum.com
post #1 of 10 Old 03-16-2011, 09:55 PM Thread Starter
rafig770
2004 KJ Liberty
Car Stereo
Hey,
I wanted to get a new simple car stereo for my car. I wanted to know if it's easy to install and if I need any other parts to install this stereo.
http://www.amazon.com/Sony-CDXGT340-Player-Receiver-Black/dp/B002OQ1J08/ref=lh_ni_t_
Thanks.
rafig770 is offline
post #2 of 10 Old 03-16-2011, 10:07 PM
Cannonball
1996 CJ5
It may be a little more difficult that you think. New vehicles using a databus or Lan system as the Jeep does will require an interface module to change out the factory head unit.
If you do it your self do not go old school and try to cut the plug odd and hard wire it, you will damage the vehicle and possibly take out a computer.
Get qualified help and the right parts from a stereo shop and then try it your self.
Ask me anything else in a PM and Ill redirect you to my work email I do car stereo and 12 volt electronics for a living!
CB
"It aint bragging if you can do it!"
1996 YJ-5 400 SB Chevy, Proflow EFI, NV4500 Trans with 6.34 low, Dynatrac HP Dana 60 Rear / Dana 44 front and 4:88 gears Featured in Sport & Utility June 1997.
Cannonball is offline
post #3 of 10 Old 03-16-2011, 10:46 PM Thread Starter
rafig770
2004 KJ Liberty
Thanks.
rafig770 is offline
post #4 of 10 Old 03-17-2011, 07:07 AM
WXman
On the Liberty, it's a cake walk. One of the easiest installations I've ever done. You need a wiring adapter and a mounting kit...both available at Walmart for less than $20, and you need an antenna adapter, which is available from places like Crutchfield. Then all you do is connect the wiring from the adapter to the wiring included with your new radio. Use crimp caps to do this (also available at Walmart). Then...the new radio is simply plug and play.
I can do one in less than 30 minutes on the KJ. There's only one screw and then the entire bezel around the radio pops off.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #5 of 10 Old 03-17-2011, 09:44 AM
bham-x
2003 KJ Liberty
I changed mine out myself last christmas. It wasn't bad at all.
"On a long enough timeline, the survival rate for everyone drops to zero."
bham-x is offline
post #6 of 10 Old 03-18-2011, 07:50 AM Thread Starter
rafig770
2004 KJ Liberty
Thanks guys.
I just went to the store and I was about to have the geek squad install it but I decided to try it myself. He gave me all the adapters I need but I asked him about the steering wheel controls and he said that part would cost $100 for it to work.
More info please, I need at least the volume to work, I use it all the time.
rafig770 is offline
post #7 of 10 Old 03-18-2011, 07:14 PM
Cannonball
1996 CJ5
Dont know what radio you are using but for the Pioneer radios I use the PAC interface
http://www.pac-audio.com/productDeta...&CategoryID=29
$85 on line
For all other interfaces check out http://www.pac-audio.com/products.aspx
They make a good product!
CB
post #8 of 10 Old 03-19-2011, 05:40 PM
01CHEEKEE
What's the antenna adaptor for? Is it necessary?
01CHEEKEE is offline
post #9 of 10 Old 03-19-2011, 08:14 PM
WXman
It allows you to connect the factory Jeep antenna to the back of your new aftermarket head unit. Yes, it is necessary if you want to listen to AM/FM stations.
As far as steering wheel controls go... get the Axxess ASWC adapter. It's only $69 shipped from Crutchfield, it only takes 3 wires to hook up to the Liberty, and it works like a charm. It's by far the easiest and best solution to keep your steering wheel buttons useable. (Mine is a Pioneer unit...I assume other brands will be the same).
WXman is offline
post #10 of 10 Old 03-19-2011, 11:51 PM Thread Starter
rafig770
2004 KJ Liberty
Long story short. On Thursday I went to Best Buy. I bought the stereo the wire adapter and the mounting kit. He told me Geek Squad can install it for $49 but I decided to try it myself. Well he didn't tell me about any antenna adapter until I am ready to plug everything in after connecting all the wires. I thought I was doing something wrong but now I see I need an adapter. I am going back tomorrow.
Thanks for the steering wheel information.
rafig770 is offline
CD won't eject from RBK Stereo dac122 KJ Liberty Forum 7 05-18-2011 12:16 AM
New stereo question Rocket KJ Liberty Forum 17 03-04-2010 07:37 AM
Hi all, Stereo help needed.... neilb KJ Liberty Forum 5 01-05-2010 03:39 PM
getting the stereo out?..... kaketj KJ Liberty Forum 2 03-04-2006 10:47 PM
car stereo tycooct KJ Liberty Forum 4 07-07-2004 11:28 AM
