Can't read error codes. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Can't read error codes.
Spartan Locker's at all time LOW exclusive from ROCKRIDGE FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Bds fox ipf 2.0 racing series shocks now available at rock
Unread 07-11-2013, 08:02 AM   #1
SIGP2101
2006 KJ Liberty
No matter what I do I can't get my Jeep Liberty Limited 2006 3.7L to spell out codes for me. I am utilizing key method. I got CEL yesterday first time ever and I am curious where to start troubleshooting but can't get codes out.
Tried following methods:
Off-On
Off-On
Off-On, within 5 seconds, nothing
On-Off
On-Off
On-Off
Tried all of the above with pressing and without pressing trip reset button. but no codes. Can any one provide any advice? Is there any other method other than going to garage.
SIGP2101 is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 09:18 AM   #2
tjkj2002
2002 KJ Liberty
Some years that key trick does not work.
tjkj2002 is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 03:11 PM   #3
DaveJKJ
2005 KJ Liberty
Yes, my 05MY will read codes with the key trick. They might have stopped it with the 06MY like the OP has? Not sure what years they stopped. Last I knew it worked with 02-05MY but not sure after that.
IIRC it is.......on....off......on.....off and then on .....and codes will display or it will say "done". Haven't done it for awhile now.
War Veterans Jeep Group #31
Black Jeep Society #217
DaveJKJ is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 10:15 PM   #4
streetglideok
2005 KJ Liberty
Off-On
Off-On
On-Off
On-Off
On-Off
Even with the key method, you still need a device to check for codes, as not all codes will always come up, and in many cases, if you don't wish to guess the part that is bad, you need datastream capability.
streetglideok is offline   Reply With Quote Quick reply to this message
Unread 07-12-2013, 01:39 AM   #5
Billwill
2002 KJ Liberty
Off-On
Off-On
On-Off
On-Off
On-Off
The Trip Reset button has got nothing to do with it.
Holding in the Trip Reset button while turning ON the ignition will excercise the cluster...turns all cluster lamps on and moves the gauges around then ends with a display something like "2.4" which is the software level of the cluster.
I do not believe that the 2006 KJ supports the key method of pulling codes...they changed the protocol from PCI to CAN in 2006 and I think they decided not to have the key method anymore...rather have KJ owners pay the Dealership to have codes read
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline   Reply With Quote Quick reply to this message
Unread 07-12-2013, 07:37 AM   #6
SIGP2101
2006 KJ Liberty
Code is gone, CEL is gone. I cleaned IAC two days ago and CEL is off this morning. Jeep idling at 550 RPMS like brand new. Also noticed immediate fuel economy improvement.
THANKS to all for the input!
Unread 07-15-2013, 09:56 AM   #7
Luke09
2005 KJ Liberty
The KJ gets cranky when that little bugger is dirty Glad to hear your runnin smooth.
2005 Liberty Renegade - Dark Khaki
Frankenlift IIP, Mobil1 Synth.& Filter, PIAA Extreme White, Amsoil EA Filter, Spidertrax 1.25, 245/75/16 Duratracs
Luke09 is offline   Reply With Quote Quick reply to this message
