Can I add steering wheel radio buttons myself? - JeepForum.com
post #1 of 5 Old 10-16-2010, 02:17 PM Thread Starter
2005renegade
2005 KJ Liberty
Wondering if (or how to find out if) it is possible to add factory steering wheel radio controls to my Liberty.
Are they all wired for it, or would it have to be wired, and does it depend on which radio you have.
Anyone tried it? Success? Any help or advice appreciated...
2005renegade is offline
post #2 of 5 Old 10-17-2010, 08:47 AM
joelwg
2005 WJ
I would not say yes for definate, but you can on the wj and the info is on wjjeeps.com if it helps. If you take off the airbag Carefully and check your clockspring there should be a connection for the harness. It is a really simple job, I'm just in the middle of doing my wj. You will then need the controlls and possibly to cut out the blanks on the reverse of the wheel, or get a complete wheel from a breakers with everything you need. I would keep as close to the same year as possible to make things easier.
joelwg is offline
post #3 of 5 Old 10-17-2010, 09:08 PM
CATCRD
2005 KJ Liberty
Yes, I have done it. A buddy got the buttons with their wire pigtails from a junkyard. You need to remove the airbag, pull the steering wheel off with a wheel puller and get the backing plastic off. Cut holes in that to fit the buttons and reassemble. If your KJ came with a premium BCM (if you have remote locking doors I think is one indicator) then the pigtails just plug right in and the stereo will recognize them. Added cruise buttons at the same time, but needed to take it to the dealer for them to enable that bit in the software.
CATCRD is offline
post #4 of 5 Old 10-18-2010, 05:59 PM Thread Starter
2005renegade
2005 KJ Liberty
Cool. Good to know. Is the airbag removal straight forward or difficult? I've looked into doing it on other cars before, but never completed it.
post #5 of 5 Old 10-18-2010, 06:58 PM
tjkj2002
2002 KJ Liberty
Make sure you disconnect the battery and turn the headlight switch on and walk away for 15-30mins(to drain SRS system capaciters) then come back turn off headlight switch and then remove the airbag.Make sure all SRS system connectors are securely plugged in before hooking the battery back up to prevent any accidental firing.
tjkj2002 is offline
Steering wheel radio controls babes66 KJ Liberty Forum 4 04-10-2009 01:12 PM
Steering wheel mounted radio controls psujeeperman02 KJ Liberty Forum 1 10-29-2004 06:42 PM
steering wheel radio control on a sport LIYANG KJ Liberty Forum 10 09-18-2004 09:33 AM
Steering wheel radio controls psujeeperman02 KJ Liberty Forum 1 06-30-2004 03:08 PM
Adding radio steering wheel controlls Renegade04 KJ Liberty Forum 0 05-03-2004 07:14 PM
