Camshaft gear timing help! - JeepForum.com
post #1 of 7 Old 12-18-2010, 07:47 PM Thread Starter
cgi2099
Working on a 2002 Jeep Liberty V6 3.7 with blown heads, long story short i had the camshaft gears at top dead center with the V6 mark a 12 o'clock position and the crank lined up with the top dead center line. Pulled the heads replaced gaskets and had every thing ready to go back together and while i was at the parts store the guy i was working with turned the crank with the chains back on with everything still at top dead center the gears ready to go without the secondary chain idlers on, and some how the passengers side cam chain skipped a sprocket on the crank gear when he turned the crank and is not top dead any more but still lines up with the orange dot, what do i do to correct this problem. How do i make sure everything is top dead center after i figure out how to fix this problem.
I really need help with this one guys,
Josh
cgi2099 is offline
post #2 of 7 Old 12-19-2010, 12:04 PM
richd
2008 KK Liberty
Josh
TDC is when the no.1 piston is at the top,and both valves are closed.
richd is offline
post #3 of 7 Old 12-19-2010, 05:44 PM Thread Starter
cgi2099
the chilton manual I'm using says that the drivers side should be closed and the passenger should be open, is that correct?
cgi2099 is offline
post #4 of 7 Old 12-19-2010, 06:11 PM
richd
2008 KK Liberty
Just worry about the #1 cylinder,piston on top,both valves closed,and make sure your on the right stroke.When you think its at TDC,rock the engine just a little bit by hand,and the valves shouldnt move.
richd is offline
post #5 of 7 Old 12-19-2010, 06:29 PM Thread Starter
cgi2099
how do I know what stroke I'm on and how do I check to see if the number one cylinder is on top with the heads on?
cgi2099 is offline
post #6 of 7 Old 12-19-2010, 06:39 PM
richd
2008 KK Liberty
Youll have to take out the spark plug,and see if you see the piston.If you have the valve cover off,then you can see the valves.At work we had a whistle hooked up to a hose,and screwed in the plug hole,turn over engine,and when the whistle blew it was TDC.
richd is offline
post #7 of 7 Old 12-20-2010, 04:18 PM
blk00rt
2007 KJ Liberty
i always put my finger over the spark plug hole and when the piston is at the top of the hole, your finger will be forced off the spark plug hole.
blk00rt is offline
Camshaft Positon Sensor swingbatta KJ Liberty Forum 3 08-14-2012 06:56 PM
CRD Timing belt replacement GDE KJ Liberty Forum 14 05-06-2010 09:34 PM
CRD timing belt tools? dieseltoyz KJ Liberty Forum 9 04-23-2009 10:03 PM
Camshaft Siezed 2.8crd Kj AUSSIEKJ KJ Liberty Forum 2 12-31-2008 02:36 AM
Changing CDR timing belt Panda KJ Liberty Forum 2 06-17-2006 09:14 PM
