Cai - JeepForum.com
post #1 of 23 Old 02-26-2010, 11:40 AM Thread Starter
sevenn07
2005 KJ Liberty
Cai
I have wondered about CAIs and had started to hijack a thread and didn't want to do that. So my question is I found a link to a CAI that uses the stock air box and runs an intake tube to a position by the radiator. I think it is 3in tube running in between. I would like to hear the thoughts on that. I also want to know what would be the best filter to run in the stock box. I really want to get some easy, bolt on, reversible power. I am not looking for huge jumps or gains in power or mpgs but maybe a little bit. I also will probably run a new muffler to open up the exhaust. I would like to hear your ideas. I expect a lot of differing ideas just don't eat at each other or me. Just give me YOUR opinion on the subject.
I never get stuck, only temporarily delayed.
Silver Jeep Member #32
Arkansas Jeep Club Member #32, Go Hogs!
Woo Pig Sooie
sevenn07 is offline
post #2 of 23 Old 02-26-2010, 02:38 PM
T-birdJunkie
2002 KJ Liberty
ThunderbirdJunkie doesn't think it'll make a huge difference.
But then again, people have seen his cold air intake.
T-birdJunkie is offline
post #3 of 23 Old 02-26-2010, 03:13 PM Thread Starter
sevenn07
2005 KJ Liberty
Did you get the one off lost KJs I think it was. The guy was making it from a 3D Plastic Printer is what i am going to call it. and it hooked onto the stock box and whatnot? I think he may have mentioned you in the thread. But not totally sure. I liked his idea where to get air from. And can you run a better filter from within the stock air box?
Woo Pig Sooie
sevenn07 is offline
post #4 of 23 Old 02-26-2010, 05:19 PM
T-birdJunkie
2002 KJ Liberty
Nope, this is ThunderbirdJunkie's cold air intake
post #5 of 23 Old 02-27-2010, 06:52 PM
tommudd
2004 KJ Liberty
After 135000 miles trying several different setups the best so far
Amsoil filter, stock box with 3 inch dryer vent hose to the grill, works good.
TBJ may have a better setup , but
tommudd is offline
post #6 of 23 Old 03-01-2010, 11:21 PM Thread Starter
sevenn07
2005 KJ Liberty
Nice set up TBJ. And thankyou tommudd. I would love to go like you TBJ but I don't want to do anything that is not reversible unless it is a factory option. I do think I will go as tommudd says. But if I sell my truck then I may do what you have TBJ.
Woo Pig Sooie
sevenn07 is offline
post #7 of 23 Old 03-01-2010, 11:28 PM
T-birdJunkie
2002 KJ Liberty
It's only the 3" hole you have to holesaw into your fender that hurts.
After that, it's all gravy baby!
post #8 of 23 Old 03-01-2010, 11:35 PM Thread Starter
sevenn07
2005 KJ Liberty
That is the part that scares me. Did it help low end power or gas mileage out any?
Woo Pig Sooie
sevenn07 is offline
post #9 of 23 Old 03-01-2010, 11:45 PM
T-birdJunkie
2002 KJ Liberty
Nope, but ain't killin that motor if water depth gets misjudged
Might kill a few other things, but the engine's the most expensive single part
post #10 of 23 Old 03-01-2010, 11:53 PM Thread Starter
sevenn07
2005 KJ Liberty
Have you gotten your engine sealed off? or do they come sealed?
Woo Pig Sooie
sevenn07 is offline
post #11 of 23 Old 03-01-2010, 11:55 PM
T-birdJunkie
2002 KJ Liberty
That's what the snorkel's for.
post #12 of 23 Old 03-02-2010, 12:03 AM Thread Starter
sevenn07
2005 KJ Liberty
I thought the distributor had to be sealed as well. I'm guessing if you had air lockers you could run it through the snorkel as well?
Woo Pig Sooie
sevenn07 is offline
post #13 of 23 Old 03-02-2010, 12:10 AM
T-birdJunkie
2002 KJ Liberty
No distributor on a KJ
Either way, it's a precaution against sucking up water into the cylinders more than anything. Deepest water ThunderbirdJunkie normally gets into is halfway up the headlights.
post #14 of 23 Old 03-02-2010, 12:20 AM Thread Starter
sevenn07
2005 KJ Liberty
no distributor? wow I must be far behind on my engines. What does the charge for the spark plugs come from?
Woo Pig Sooie
sevenn07 is offline
post #15 of 23 Old 03-02-2010, 12:21 AM
T-birdJunkie
2002 KJ Liberty
Independent coil on each plug for the 3.7, 2.4 has a single coil pack to power all 4 plugs ITBJRC
cai , liberty
