A/C low pressure switch - JeepForum.com
post #1 of 8 Old 04-05-2010, 12:23 PM Thread Starter
Gomofast
Gomofast's Avatar
Can you replace the low pressure switch without venting the system? I need to replace the switch, but I don't know if all the freon is gonna come out. It would be lovely if the bung was fitted with a schrader valve to maintain system pressure when changing the switch.
08 JK Unlimited X, 2" Black Diamond lift, 33's, 1.5" wheel spacers, stubby bumper mod.
98 TJ Sport, 4" Rough Country Lift, homemade discos,
35" BFG Mud Terrain T/A KM's, 4.56 gears, Detroit Truetrac
up front, factory Trac-Lok out back,Warn M8274 8000lb
winch, York OBA, rock guards, custom intake, 48" HI Lift.
Gomofast is offline
post #2 of 8 Old 04-05-2010, 01:30 PM
Slithering_Joe
According to the 2005 KJ service manual is not neccessary to discharge the A/C system to remove the switch.
4.0L TJ
Slithering_Joe is offline
post #3 of 8 Old 04-06-2010, 01:19 PM Thread Starter
Gomofast
Gomofast's Avatar
So there must be a valve built into the bung (where the switch screws in) to retain pressure?
Gomofast is offline
post #4 of 8 Old 04-06-2010, 02:43 PM
Slithering_Joe
I would assume it is has a Schrader valve just as in the Ford A/C system. (My GM turd does not. You must evacuate the system to replace the switch.)
post #5 of 8 Old 05-13-2011, 06:34 PM
Libbyowner
I bought a jeep few months ago. And make the long story short, I just found out I need to get the low pressure sensor switch/sensor replace. So, do I have to vent out the system before I unscrew the sensor?
Libbyowner is offline
post #6 of 8 Old 05-13-2011, 06:42 PM
Libbyowner
P.s. Is there a schrader valve in the low pressure sensor?
post #7 of 8 Old 05-13-2011, 09:42 PM
richd
2008 KK Liberty
According to my SM,it says you dont need to discharge the A/C system to replace switch.
richd is offline
post #8 of 8 Old 03-25-2012, 08:47 AM
Libbyowner
So here is my answer to the Jeep liberty A/C problem. According to my AC mechanic, it is a very common issue with the Chrysler AC compressors.
1. Turn on your AC to full blast in a warm day.
2. Open the hood, locate the AC compressor which should be on top and right in front of you.
3. Use a stick or a rock (just anything but your hand), and turn the compressor clutch clockwise.
4. If it engaged, cold air should flow into your car, which means your AC actually works, it just needs to re-shim.
5. Go to locate AC/Radiator specialist, pay them $50, it should take about 30 mins and you should be good to go.
a/c , ac switch , low pressure , pressure switch
how to remove connector to oil pressure switch hawk1996 KJ Liberty Forum 11 01-21-2014 08:03 AM
oil pressure switch wiring yesirem KJ Liberty Forum 0 12-11-2009 02:59 PM
Question about Low pressure switch on 2002 f150 KJ Liberty Forum 1 08-13-2009 01:11 PM
Low Pressure switch gahendo KJ Liberty Forum 0 05-26-2008 06:56 PM
Oil Pressure Switch Question modernist KJ Liberty Forum 3 09-21-2007 01:12 PM
